Custom Engine Compartment
All is well ... My nephew took a high onside baseball to the head and got knock out for 24 hours. Docs took xrays MRI scan all the bloodwork.
Doc is a long time family friend. QOUTE " He's got nothing but skull and bones in there, just like the rest of hes hard headed Spartan uncles!"
The boy is home now and will be cleared for duty in a week or two.
thank you all for your concern and kind words.
Glad to hear he is doing OK
Those are the original ones,I just painted them with the a red anidise paint from Advance auto parts. I just took them apart ,sanded ,primed then used the silver base and then the red paint. I'll be changing them out for some after market fuel rails in the near future. but till I do they look alright. hope this helps.lol
Had them powder coated FORD BLUE. I will install them when i get the
valve covers from the coater.
Not hard at all. 4 bolts and disconect the fuel line. I also took off the two bolts on the fuel rail block. Although I replaced my fuel lines with braided ones. after taking out the 4 bolts and disconecting the line, slowly pull up on one fuel rail at a time,they come up pretty easy. take them off as an asembly.
Well a little more information would have helped, like you need to release the fuel pressure and you need a special tool to disconnect the fuel lines but all in all it worked out alright.
