Confused on Exhaust Terminology
Old Jul 24, 2007 | 06:03 AM
GOarmy08's Avatar
I'm looking to go with Hooker LT headers, the Hooker O/R Cross-pipe and some other sort of system to finish it out. That "some other sort of system" is the part I don't under stand... Is this part called the cat-back, axel-back, or something else? Do I need a specific exhaust to go with this set-up (i.e. "Aero Chambers" kit that comes with hooker full kit). Am I missing a peice? I just want a full 2.5" stainless, mandrel-bent kit, without using the aero chamber muffler/tips.
Old Jul 24, 2007 | 07:11 AM
nynvolt's Avatar
That other system would be an axle back. "cat back" systems replace your mid pipe(s) in our case an "H" pipe and the mufflers. "Axle back" system is just the muffler replacement. So if your already replacing the H pipe then you only need the muffler/axle back.
Old Jul 24, 2007 | 07:30 AM
GOarmy08's Avatar
thanks a lot for the help. would other brands align with what I have selected, so I can mix and match the axel-back?
Old Jul 24, 2007 | 10:49 AM
GOarmy08's Avatar
I'm looking to go with the Hooker LTs, cross-pipe, and flowmaster CBs... Is this possible w/o having to butcher up one of the kits?
Old Jul 24, 2007 | 04:33 PM
Bingo's Avatar
Flowmaster doesn't make a catback as far as I know...only an axle-back. Your Hookers and off-road X will bolt right up to your mid-pipe, no cutting. Hookers, off-road X, and Flowmaster mufflers should require no butchering.
Old Jul 26, 2007 | 12:23 AM
GOarmy08's Avatar
Sweet. Thanks a lot Bingo.. I think this will create the exact sound I'm looking for.
Old Jul 26, 2007 | 05:36 AM
Bingo's Avatar
I'd caution about Flowmasters and X-pipes...I think it sounds like crap - really raspy. But if that's what you want...
Old Jul 26, 2007 | 10:17 AM
GOarmy08's Avatar
great... now I'm second guessing myself... Can anyone else chime in on the LTs, O/R x-pipe, flowmaster set-up? Rasp, loudness, drone, or tingling feeling factor you get when you hear this set-up?
Old Jul 26, 2007 | 11:28 AM
don_w's Avatar
I have no direct experience with the Flowmasters, but with LTs and O/R x-pipe, a lot of mufflers sound like crap (i.e., trumpeting). I ditched a set of LMs and Bassanis because of the embarassing trumpets. I was going to just put the stockers back on, but then I tried a set of Magnaflows, and they worked pretty well at killing the trumpets.
Bryanh24
Oct 14, 2015 08:43 AM
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
