Concrete evidence of blown engine on boost?
Originally posted by GOFISCH@March 4, 2005, 3:23 PM
Anyone know anyone personally, or seen a blown engine on boost yet? The rumors are flying on other forums that the new GT engine is weaker than previous GT engines. I haven't seen any concrete evidence. Just the facts please.
Hi Jeff,
While I cannot give you direct info on the 05 GT 4.6 I have VERY personal knowledge about supercharging a 4.6. I had a 96 Cobra that I put a Kennebell supercharger on. The engine was completely stock. I ran a 6 lb kit for 2 years without any problem. Like all motorheads I wanted more. I raised the boost to 8-9 lb. kit. It was on the car for 2 weeks when I made my 1st and only pass down the 1/4 mile. That 12.5 seconds cost me $6,000.00 and one real pissed off wife. I knew I was in trouble when I went thru the lights sounding like 25 lbs of nut and bolts thrashing around in a metal trash can.
After tearing down the motor what I found was awful. I had 5 shattered pistons from the ring lands up and 2 pistons broke off at the wrist pins, which in turn punched holes thru the block.
For those that may not know that motor has a forged crank, powder metal rods and hyperpathic (this is how they should spell it) pistons. The pistons in these motors are the weakest link. While they are great in stock application for 200,000 miles they are worthless on a blower motor. I rebuilt the motor with forged components from Manley and it is still running with 8 lbs of boost to this day.
I personally believe that the Ford 4.6 is an awesome engine in its stock form and the Kennebell Superchargers are the best. Bottom line is never exceed 6 lbs of boost on a stock motor. And if you feel the need for speed then yank to motor and build it with forged stuff. It is also a must to run the best gas possible. 93 octane minimum.
What happens when you up the boost is the engine starts to detonate. At WOT it is like hitting the top of your pistons with a sledge hammer. The stock cast pistons and rods can't take it. One 1/4 mile run was all it took for mine. I should have been running 100 octane for that boost level but could not get it at the time. Bad decision on my part. And by the way the computer and the knock sensors cannot react fast enough to back the timing off when this detonation starts. I check my computer to see if it had any codes for detonation and it was clean. I learned the hard way as most of us do. Just be careful. If you search the net for 4.6 Mod Motor blow ups you will find it happens just like I decribed above. ALOT!!!!
70Mach1Owner
8-9 pounds of boost did that? I've seen stock cobras w/ 12 lb's of boost as daily drivers...and have plenty of miles on them. I've seen some get greedy and blow them up too, but never running only 8-9lbs of boost.
2005MustangGt
I am assuming the stock Cobras you are talking about that run 12 lbs of boost are 2003/2004 Cobras. They have forged guts from the factory. 1996 thru 2002 Cobras are not forged guts. Neither is the 2005 GT 4.6 Put 8 or 9 pounds on one and you playing with a bomb. When you daily drive you are not at WOT thru all gears all the time. Thats when they will blow.
70Mach1Owner
i say we wait and see when one blows up... if one blows up
NOBODY here can decide if they can/cannot handle boost, just because something looks and sounds weak doesnt necessarly mean that it is
so until someone blows one up/doesnt blow one up, i think all we should hear is crickets....or BS
WARNING: GUT FEELING
If I remember correctly, the 3V 4.6L can only handle about 8 lbs of boost before running into problems... this goes to the material the pistons are made from and the geometry of the mechanicals...
There is a much older thread concerning this from a while ago that got into some technical detail...that's about the best I can do at 1am
Originally posted by GOFISCH@March 4, 2005, 8:55 PM
70MACH1OWNER, ok but thats not a 05 GT engine in your story. They are not the same engine. Again I ask facts on the NEW GT engine with F/I. Thanks guys.
GOFISCH,
You are correct. It is not an 05 3V engine story. But this is fact. The pistons are the same hypereutectic junk that was in my 96 cobra. This is the weakest part of the internals in the engine. I am just tring to save you guys the grief and expense I when thru. It really doesn't matter what year the engine is. It is a matter of good engine building science. Remember, all I am saying is keep the boost down to 5 or 6 lbs on a stock motor, run good gas, and you should be fine.
By the way when Ford builds a blower motor for the Cobra and Lightning they use forged internals. Wonder why???
I would also suggest you make a call to someone like Sean Hyland. He has made a mint replacing short blocks for people that made the same mistakes I did.
70Mach1Owner
Guest
Posts: n/a
Originally posted by 70MACH1OWNER+March 5, 2005, 5:29 AM--><div class='quotetop'>QUOTE(70MACH1OWNER @ March 5, 2005, 5:29 AM)</div><div class='quotemain'><!--QuoteBegin-GOFISCH@March 4, 2005, 8:55 PM
GOFISCH,
70Mach1Owner
[/b][/quote]
Thanks Scott, I understood what you were saying. I'm just tired of reading how all these people have blown their 05 GT engines. When in fact there is no proof that it HAS been done already. If it has happened, I'm sure this board would know about it.
GOFISCH,
Give it some time, there will be some of the 05 GT engines to be broke. If it can be done, (and it can) it will be done, someone will want just a little more. Heck you have heard of 03/04 Cobra engines and plenty of GT engines to be broke before. From all I have read the weak link in previous GT engines has been the pistons and the 05 GT pistons are even more of a weak point for SC engines. Most likely you could take an 05 GT engine put 5 or 6 psi boost, tune it good, drive it nice, and have it last for a long long time. But, take the same engine, put 10 psi boost, don't tune it, run it WOT on the drag strip, and trailer it to the shop.
Originally posted by angcobra@March 5, 2005, 7:41 AM
GOFISCH,
GOFISCH,
AMEN GLENN!!!! :worship: :worship: :worship: :worship:
70Mach1Owner
Guest
Posts: n/a
Yea, I expect that to happen also. These are Mustang Guys, they have been doing that for 40 years. But I haven't seen one yet. Also, if everyone says not more than 5 or 6 psi, I don't think the gains will be worth $5,000 give or take a few hundred bucks. Also, I'm not really concerned with the guys trying to push the envelope. But that standard psi and tune you are talking about.
Originally posted by 70MACH1OWNER@March 5, 2005, 4:29 AM
GOFISCH,
GOFISCH,
Originally posted by mr black+March 5, 2005, 8:52 AM--><div class='quotetop'>QUOTE(mr black @ March 5, 2005, 8:52 AM)</div><div class='quotemain'><!--QuoteBegin-70MACH1OWNER@March 5, 2005, 4:29 AM
GOFISCH,
GOFISCH,
[/b][/quote]
We need to get someone who knows for sure in here but, I read a thread where they were testing some aftermarket SC on the 05 engine and the piston design was discussed. It seemed to me that the ring location was also different from the top of the piston which created a worst condition and the only saving grace was the mods you spoke of. That thread, hosted by the car owner the SC was installed on, warned of the pistons as weak link and limitations of boost to 6 psi.
Sorry to beat the dead horse again but 70MACHI is correct. The new pistons have additional silicon in them above the 'eutectic' point of the alloy(12.6%). This causes the brittleness to go up by 40% on these pistons. The higher silicon content lowers the density of the piston alloy(2.33g/cm3 vs 2.7 for pure aluminum), increases wear resistance and make the alloy more fluid for casting, but at the expense of easier catastrophic failure. My 2 cents as a Mechanical Engineer.
