Comp Cams or FRPP Cams
Im debating on which cams to get. Im N/A street driven, and looking for the most rwhp out of these two cams. I have all bolt-ons except TB, and EWP. Which of these two cams NSR would give me more power to the wheels?
Comp Cams NSR (127200) FRPP hotrod Cams |
I went with the Comp's because my car is driven in street traffic a lot. I had read that the FRPP's sometimes have driveabilty issues in the lower rpms. The Comps are much less choppy in idle, but sound wasn't a factor for me. Lately I have read some good info. on the BBR Stage I cams. They are NSR and have a higher intake and exhaust valve lift than either the Comp or FRPP NSR cams. The BBR reps. are saying it's o.k. because coil bind with stock springs is around .512, which much higher than what was previously thought.
Originally Posted by rivercitypony
(Post 6002610)
any dyno #'s on your car with your mods?
The last dyno pull ( on a conservative dyno jet) with these mods was well over two years ago, but the Comp cams increased my numbers from 319 rwhp/313 rwtq to 340 rwhp/320 rwtq. Remember, I have shorty headers, because I'm going with a turbo as a power adder. With the mods you're talking about adding, you should make at least 350 rwhp N/A, and that's with any NSR cam. BTW, not to get too far off topic, how do you like the FRPP throttle body? |
Also you can add an aluminum flywheel if all of the above doesn't get you to 350 rwhp. One good thing about your hp goal: you probably won't need a clutch upgrade, or fuel injector and fuel pump upgrades.
(Post 6002663)
The last dyno pull ( on a conservative dyno jet) with these mods was well over two years ago, but the Comp cams increased my numbers from 319 rwhp/313 rwtq to 340 rwhp/320 rwtq. Remember, I have shorty headers, because I'm going with a turbo as a power adder. With the mods you're talking about adding, you should make at least 350 rwhp N/A, and that's with any NSR cam. BTW, not to get too far off topic, how do you like the FRPP throttle body? I saw your mod list in your sig. How the HELL did you have 319RWHP without the cams? What was your full mod list then? |
(Post 6002663)
Originally Posted by Blacksmoke
(Post 6002703)
I have always heard great things about comp cams.
in fact a few wekeends ago when I was installing my stereo we installed some in my nephews focus and they are amazing in that. |
Originally Posted by Elanor05
(Post 6002879)
He dynoed on a Dyno Jet, the Dynojet numbers are slightly higher than MD's.
Even on a Dyno....that mod list is not very big without those cams. I dont see how it cold make near that much CAI... UDPs, and Deletes and that's all i really see for performance mods without his cams. |
(Post 6003052)
I dont see how it cold make near that much CAI... UDPs, and Deletes and that's all i really see for performance mods without his cams. Also I would say neither of these cams will give more significant power than the other. If you want the most power you can get you would go with like a 127500 with a spring swap or something along those lines. The frpp's sound like pure sex though. |
I was very surprised to get those numbers, believe me, but I give credit to other factors besides engine mods for my high numbers. (a) Adam at ST Motorsports is a world class mustang tuner. (b) the weight reducing mods I put on the car are underated in what they can do for performance, regaining lost hp and tq. By this I mean an aluminum flywheel, driveshaft, and some super light Enkei racing wheels that are much lighter than the stock bullet wheels. (c) I'm still using relatively light 235/55/17 tires. (d) No cats with an x pipe is great for top end hp. (e) I use synthetic oil and fluids everywhere on the car. Heck I even stepped down a viscosity level for the rear differential--an old racing trick to get more hp. (f) I have Brisk racing spark plugs and some MSD cops in the car as well. It all adds up when you're going N/A. But now it's time for a turbo as a power adder. However the mods I've listed above will still be there helping with overall performance, so I can't complain.
(Post 6003174)
pardon my ignorance but what is NSR?
(Post 6002703)
How the HELL did you have 319RWHP without the cams? What was your full mod list then? These 4.6's respond well to mods :) http://i55.tinypic.com/2uj2xdz.jpg |
Originally Posted by fdjizm
(Post 6003431)
My car got 323hp on a dyno jet, it's possible with minimal mods, good tune helps also.
These 4.6's respond well to mods :) [img][/img] |
Originally Posted by 2kanchoo
(Post 6004008)
This is pretty well exactly what I had before the cams. Then my tq stayed close to the same and I gained about 30rwhp. :dunno:
