Clutch Replacement Questions
Old Sep 24, 2012 | 02:39 AM
metroplex's Avatar
How difficult is it to replace the clutch? Is this a job that I can do myself in my garage without a lift or removing the engine?
If I need to have a shop perform the task, how much will it generally cost?
Old Sep 24, 2012 | 07:27 AM
muscledom's Avatar
It'll be a ***** on your back. A shop should only have to charge you MAX 5 hours of labor. Should really only take 4. Make sure you get your flywheel resurfaced.
Old Sep 24, 2012 | 08:50 AM
metroplex's Avatar
Should I go to the dealership or a performance shop?
Old Sep 24, 2012 | 09:12 AM
BradGT's Avatar
Dealer would most likely have cheaper rates
Old Sep 24, 2012 | 09:42 AM
muscledom's Avatar
Find a decent shop. It's not a rocket science job. Dealer will be like $98 per hour and a performance shop will likely be the same. Shouldn't cost much more than $300 total with the flywheel being resurfaced, for labor.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
ssjbuu
Aug 28, 2015 08:55 AM
Mug-stang
Jul 31, 2015 10:25 PM
stewarts359
Jul 21, 2015 03:39 PM
