Changing Tranny Fluid - Manual
Old Dec 22, 2005 | 11:39 PM
OCCSilverGT's Avatar
How in the world do you get the new tranny fluid into the tranny! I looked and there is no possible way to get it in there. Need help!
Old Dec 23, 2005 | 07:14 AM
Firedude's Avatar
Most of your Auto Part stores have a small pump that screws right onto a trans fluid bottle. I got mine at Checker and it works nice.
Old Dec 23, 2005 | 04:43 PM
davids2toys's Avatar
Wow, wish I had known this...I ran about 6' of clear tube up to the front of the car , insert a small funnel,and then carefully put 3.2 qts of synthetic fluid in the tranny, gravity fed of course, so I held the funnel up high. I will add, dont forget that on the V-8, the level is 1/2 inch below the edge of the fill hole. I made a little guage for this out of a piece of mild steel ( piece of a coat hanger will work fine). Hope this helps you!!!
Old Dec 24, 2005 | 10:29 AM
Thanks for the much needed help!
Old Dec 24, 2005 | 12:17 PM
no problemo......I will add this, go with the shortest/ most verticle route from funnel to fill hole, and push it deep in the hole and verticle. If you do it this way you will not spill a drop.
Old Dec 24, 2005 | 01:31 PM
another question, i looked in the owners manual(which was no help) and they gave a picture of where you pour the fluid into. Well i got it up on a lift and there are, seems to be, a plug with on the side of the tranny, similar to the drain plug on the tranny, and also a black plug kinda angled on the top of the tranny. Which is the filler opening. Sorry to be so dumb, but the directions in the owners manual suck!
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
mx5jhb
Sep 30, 2015 04:44 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
Kalel08
Sep 29, 2015 03:06 PM
