Cervinis Ram Air Hood CAI question.
I just installed a Cervinis Ram Air Hood on my 2008 GT.
I would like to add the Ram Air Kit to make this a functional hood.
My question is:
What CAI will fit with little or no modification with the theRam Air Kit from Cervinis? OR does it really matter.
I current have a Steeda 90mm CAI and not sure if the Ram Air Kit will fit.
My question is:
My question is:
My question is:
I've got the Steeda CAI and have had two different hoods with ram air , but the ram air was built into the hoods and not a separate piece. The opening in the hood will sit over the CAI box and in most cases be a smaller width so it won't interfere with the box. However depending on whether or not the hood is raised , the top of the box might hit it and need to be trimmed. You really won't know till you put it on and see ...
Yea, That's want I was think too. The ram air is a separte piece and I do feel that it will hit the Steeda CAI Heat shield. CAI heat shield does come right up to the hood to shield the heat form the engine. I could trim the heat shield, but I only have about 1 inch to play with before the flange comes into play. There are no specs for the Cervinis ram air that I could find, and at $300.00, I just don't want to throw money down the drain.
