Cams + longtubes
Cams + longtubes
Just wondering in a ball park range how much hp will I get with a set of cams and long tube headers. Anybody with this combo please let me know and also will it sound sweet. Thanks
I did Comp Cams, longtubes and delete plates back in 2008. I netted 42 rwhp and like 11 lbs torque on Brenspeeds dyno. Both the before and after were on Brenspeeds dyno just at different days but similiar weather conditions.
frpp hotrod cams, stainless works lt's+full exhaust (no cats). Can't say how much power I gained for just those two because I did multiple mods both times. I'd say 35-40rwhp is for sure reasonable for the two mods.
http://www.youtube.com/watch?v=4rde63le2eA
BTW, what gain are you supposed to get with the delete plates??
THAT sounds meaner'n hell, brother......I got about 2k for a budget right now, and cams had made the list, but I'm still kinda on the fence about headers or intake and TB......most of what I've read is that cams and headers are the combo, and she do sound like a dragster......
Deletes are good for 8-10 rwhp
Well I changed my mind on the cams cause I don't know anyone who could install them just a shop which will probably cost a good chunk of cash. Cams aren't cheap either, might just go with the long tubes and delete plates, what do you guys think.
You will still feel a difference with long tubes and delete plates. Not as much an cams but there is still a horsepower gain. Its going to be a good choice either way. It just depends on how much you are willing to spend.
I agree. The cams are the biggest gain between the choices. But the sound difference doing the longtubes is worth it!!!!
Originally Posted by 5pointoh
Are the delete plates worth the money? Probably even more benefiical with a SC? It seems like Steeda really is the only brand out there?
Keep in mind you'll need a tune with them as well. If you buy them from the same place you got your cai+tuner from they'll usually give you a new tune for the plates for free.
Also keep in mind that the aftermarket intake manifolds delete the plates as well. If you have any intention of the frpp or cnl intakes, don't bother with delete plates.
Cams and long tubes.
I know this is a old thread but, I just bought a lot of mods for my 06. I just bought hot rod cams, bbk long tubes and made about 35+ more hp. 340 rwhp. My other mods are jlt cold air intake, bbk o/r x pipe, pypes cat back, and S.r. Underdeive pulleys. I plan on buying fr intake manifold and tb. But if I were you cams are expensive but if you can find the right guy to tune you right, they're worth it.
You can get a little more peak hp this way, but IMHO, if you're already at 340RWHP, I don't know if the extra 10-15 hp is going to be worth the $1200 to get there. I've got JBA long tubes, catted H-pipe, cams, the FRPP intake & TB, and a Granatelli CAI. I'm making 350HP @ the wheels. Granted, the cams are Comp Cams stage ii SPR, so they focus more on mid-range gains rather than peak @ high rpm. Even still, my shop pointed out that yes, the FRPP intake flows more air, but has the effect of shifting your power curve to higher rpms, at the expense of lower end power. Even with my SPR cams, I didn't gain any low end HP. I didn't lose any either over stock, but had no gains till 3500 RPM.
They even went so far as to tell me that I shouldn't get rid of my old stock intake manifold, so if I ever go with a centrifugal s/c I can still keep a decent torque curve at the low end.
I guess it depends what you want it for but I heard you already lose low end with the hot rod cams, I can only imagine it would get worse
