CAI KNN vs....??!?
Originally Posted by Victorfriessen
2008 mustang Gt
But I do hav a tune,and it still doesnt get near to what Im used to with my 2005 corvette, or are mustangs just like that? Would headers improve it to?
I currently have a SCT with a bama tune and Im running 91 octane gas,also I do have detroit rockers installed,do cams make it slower to?
Cans really shouldn't effect your rev speed that much.. the tune is the biggest problem with the throttle responce.
Now I'm not experienced with aftermarket larger throttle bodies (cause I don't see a point for them unless your boosted) but my buddy swears it makes the rev time much faster. Says the throttle responce is much more snappy
The cams are called detroit rockers,but thanx for the info,first thing is gona try a diferent tune
I'm gonna safely bet the tune is your issue
If I recall correctly, there's actually some deadspace physically built into the pedal. The stock tune has terrible response. If you didn't feel a difference, then I'd definitely send BAMA an email or give them a call. Also make sure that you're using the "Race Tune", and not the "Street Tune."
Since you have cams installed, they will actually have a negative effect on the lower end of the powerband. In fact most places will make a recommendation for different gearing to compensate for the difference in power. In a NA setting I would think you need 3.73s or above to get a better response off the line. Some places recommend at least 3.90s or 4.10s due to the difference. I would check into that first because the tune won't fix the powerband distribution.
