Bumpsteer Kit
Has anyone installed a bumpsteer kit on their S197? I've got a Steed kit laying out in my garage and was going to install it soon. I am just looking for pointers or tips for the install.
I just had the Steeda Bump Steer Kit installed this week. Yesterday I had the alignment done, which is a must, so it was my first time driving with the kit. My first impression right now is that the steering feels loser on teh Highway. I will have to drive is some more to see if I like it.
Originally Posted by R3troGT
(Post 897641)
Its hard to tell the benifit of the kit unless you actualyl measure the bump steer before and after you install the kit, else you won't have any way to know how much or where it was improved.
what does it do?
hi guys,
i lowered car with eiback pro and there are LOTS of bumps in NYC. is a bumpsteer kit imperative? thanks! |
Originally Posted by YaoNYC
(Post 974377)
hi guys,
wow is the spell checker broken today :doh:
I never noticed a bumpsteer issue with the S197 :dunno: Sounds like extra parts for no particular reason. It was an issue with the SN95's but it has nothing to do with the current car. I can see new ball joints for cars as low as ones with Eibach springs for 'perfect' geometry(and the punishing the Eibach's deal out to the car), but the new car just doesn't get that out of shape when lowered. |
2 Attachment(s)
Originally Posted by kevinb120
(Post 974542)
yes yes and yes. Funny enough you just posted agreeing to exactly what I said :nice:
If you are using a very low spring like the Eibach, they will beat the tar out of the stock ball joint, and the geometry starts getting off, especially with the rear LCA's. I passed on going over a 1" drop because you should change at least 10 parts going lower when the Ultralites are perfectly fine with all the stock parts. |
(Post 974797)
I just did the stylin' basics because I haven't determined what type of power adder I'm going with later before picking things like gears/suspension so its designed around its motor and how it applies power. Even when I eventually convert to coil-overs and more hard core bits, I'm probably staying at roughly the same height as now. I figured I would address traction and braking issues as they present themselves as the mods add up, rather then building up a N/A car, then turning it into a FI car and having to change half the stuff. :grin:
(Post 974901)
I am kinda new here but this is one of the first threads I have seen about lowered cars and the bump steer kit. I have not seen any mention of the crappy stock ball joints with lowered cars either. Most say with the eibach kit you really don't need any thing else but then go on to say get the panhard rod and some better shocks and struts.
What does the bump steer kit actually do? I assume they let things travel a little eaiser? |
Originally Posted by Glenn
(Post 976170)
| All times are GMT -6. The time now is 05:58 AM. |
