Bridgestone Potenza RE750 tires installed
Old Apr 10, 2006 | 10:54 PM
nonsensez9's Avatar
I got 255/50/17 Potenza re750 tires all around on the 8th. My ****-ometer isn't all that accurate, but they do seem to stick a bit better than the Pirellis. I won't know for sure how well the launch has improved until June, when the local track opens. However launch has a much better feel to it now. The Pirellis didn't make much noise when they spun, but can definitely hear the Potezas. I'm not a daring twisty driver, nor do I have a G-meter, but they hold the road at least as well as PZeroNero. I've only had them up to 120 mph - no wierdness. And they look good, imo.
I will upload photos when the server permits it
Old Apr 11, 2006 | 01:49 PM
Gunslinger's Avatar
Did you have a hard time getting these? I just called a local shop and he said "they might be discontinued". Apparently this is an OEM size for the old Impala SS. Guess there aren't too many of those things running around any more.
Old Apr 11, 2006 | 02:58 PM
nonsensez9's Avatar
<div class='quotetop'>QUOTE(Gunslinger @ April 11, 2006, 12:52 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
The local shop normally gets their tires from a distributor in Vancouver. For the Potenza tires they had to order from Mississauga, Ontario. It took about a week. They could have ordered the Fuzion ZRi overnight.
Old Apr 11, 2006 | 05:58 PM
Dubai's Avatar
any change in speedometer?? or u fix it up?
Old Apr 11, 2006 | 06:18 PM
nonsensez9's Avatar
<div class='quotetop'>QUOTE(Dubai @ April 11, 2006, 5:01 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
the tires are nearly identical in diameter to the stock tires, 235/55/17 is 27.17 inches diameter, 255/50/17 is 27.03 inches diameter. When I get an X-Cal2 I'll program the new tire size in, but it's probably not enough to notice, maybe 1/2 mph off at 100.
edit - photos added - guess which are new!
Old Apr 13, 2006 | 01:57 AM
nonsensez9's Avatar
more photos. That last one there is finishing off the Pirellis. I still have the front tires and the spare rims have arrived [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
if different views would be handy just let me know
dohc97
17
Sep 10, 2015 09:21 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
