BMR radiator brace, ok for daily drivers
I am considering going with the bmr radiator brace to get rid of some of the dead weight of stock. In the pictures, it shows the stock with what looks like lower steering linkages.
Has anyone installed this and used it for a daily driver? Do you need to alighen anything?
http://www.bmrfabrication.com/05Mustang/RS-1.jpg
I know it says for drag racing and you are suppose to delete the sway bar (and maybe I answered my own question here, but would like you all's imput)
As mentioned, it removes the swaybar and the heavy stock radiator support. I honestly didn't see any difference on the street. As well, I don't take corners at crazy speeds. The real concern for most would be the additional roll the car would take on with the lack of the front swaybar. I just didn't notice any.
I'm interested in this, as well.
I did notice that if the sway bar is mounted crooked to the frame, that the sway bar links will pre-load the sway bar when tightened down (and this will lean the car). This kit would eliminate that problem.
I took the sway bar off once and didn't notice any excessive lean while turning, either.
Will this lighten the nose enough to raise the front end? I don't want to end up with a 4x4 again!
Wow, just $149?
Other daily drivers, chime in please!
Wow, just $149?
Couldn't we just remove the sway bar and sway bar links to save weight for free?
This kit claims a 26.5 lb weight reduction.
It says their crossmember weighs 5.5 lbs compared to the OE crossmember at 16.5 lbs. That's an 11.0 lb reduction. The rest is the sway bar and sway bar links.
So, we could save 15.5 lbs and get the same results for free.
Am I wrong?
Are there any other benefits (besides weight reducion) by having the BMR crossmember over the stock crossmember? I'm talking about for a daily driver.
Am I wrong?
Am I wrong?
Am I wrong?
you can do what you like but every lbs counts whe ndragracing because every little bit adds up. i drove for a while with just the swaybar removed. but if your removing the swaybar, your donig it for weight reduction, so why keep the extra weight of the swaybar support/radiator support when all you need is the radiator support.
I played with adjustable sway bar end links and could lean the car by inches! But this makes turning one way tight and the other way loose. No sway bar would eliminate this problem all together.
I don't drag race at all, nor do I do any high-speed cornering. Just a show car and daily driver. That's why I thought about not getting the BMR support and just removing the sway bar and the end links.
Will removing the sway bar have any negative effects over the long term? How about in a convertible? Might be a dumb question, but I'm not sure if it helps support anything.
I'm going to throw my .02 in here just because i have time to kill.
If you drive in a straight line and never corner real hard, then the mod would be a good mod for you if your only concerned about straight line driving.. but for that turn in the road taken at speed.... i beg to differ.
I've driven my car at slow speeds through turns and it handles fine with no problems....
At speed it pushes in the turns and wants to go straight into the wall or cliff.... (or on the track etc...)
I have an aftermarket adjustable swaybar and it's adjusted to the neutral position and my car doesnt push anymore...
it handles sooo much better.
If you only drive in a straight line and never fly down a canyon or hit the local road coarse racetrack, then I think this support and swaybar delete would be a decent mod. Just the saved weight alone is worth it...
I think I can save more weight by taking the fork out of my mouth and looseing a few lbs. At 185, if i lost 25-30lbs Id probably be happier and the car would be lighter.
have a good day....
jake
have a good day....
jake
Are you saying it would push without the sway bar installed? Or only if there is a pre-load on the sway bar?
I don't drag race, and I don't go to any road courses.
Another thing I'm curious about... would the sway bar delete soften the ride a little with lowered springs since you don't have the stiff sway bar?
have a good day....
jake
have a good day....
jake
My understanding is that this is mainly a drag race mod...as a daily driver, not seeing the point. Mine is a daily driver and a track car during the on season, however, I also like to carve canyon walls. I'm going to remove my bar and drive it around for awhile and see how I like it. If it doesn't bother me that much, then I'll be calling BMR for the radiator support and shed the weight. If it does bother me, then I'll just remove the bar at the track and suck up the weight.
Good idea... I might remove the bar to see how I like it.
Just a thought - can't you just remove either of the sway bar links? Then the sway bar would be pretty much just floating in there, right?
You could do that and take it out for a test drive. Probably want to wire both ends of the bar to the car. For safety reasons, you want to take it out completely if you're going to drive around for awhile. And definately at the track, although some folks have been known to just wire it up while at the track.
