BMR Front Safety Loop Bolt Size?
Old Aug 18, 2007 | 02:24 PM
GRAYPNY's Avatar
I need to know the size of the bolt that is provided with the BMR front safety loop. I know it's a grade 8 but that's it. I need to get longer ones and the orginials are on the car.
Old Aug 19, 2007 | 12:27 AM
Rich, almost certain that you'll need (2) 9/16 x 1.5" Grade 8 bolts (bolt head ID marks will have 6 short dashes).
Using a 0.350 shim, around 3 threads will protrude past the nut.
Should be readily available at Osh Hardware.
Old Aug 19, 2007 | 04:29 AM
tmcolegr's Avatar
Should be readily available at Lowe's.
Don't you mean 3/8" - 24 x 1.5"?? If memory serves me correctly they are fine thread.
Old Aug 19, 2007 | 08:09 AM
281GT's Avatar
I have the same setup. You need 3/8" x 1.5" fine thread. I ended up using a 0.350" shim also. It only head of the bolt that is 9/16".
Old Aug 19, 2007 | 08:19 AM
That's what I meant.
Old Aug 19, 2007 | 10:33 AM
GRAYPNY's Avatar
I remember that they are fine thread and that they are grade 8 but that was it. Thanks for the replies guys.
Ecostang
Nov 3, 2022 08:50 PM
