BMR Camber Bolt Question
Just want to make sure I did this right.
I installed the bolt in the upper bolt hole on the lower part of the strut. I faced the bulge towards the vehicle and faced the washer flange tab towards the tire.
I basically just slide the bolt in that way and tightened her down.
Now I have seen others that have installed the bolt in the lower bolt hole of the strut. And there are those that say to barely tighten the bolt down then loosen the lower bolt to adjust the camber.
The BMR instructions are very vague and want to make sure I put this thing together correctly.
Thanks.
Thanks.
