Best time ever last nite
I ran a 8.161 et,60ft 1.568 sp 81.09 At irwindale last nite, it`s a 1/8 mile my best time ever with my mods.I have sct tune 91, hurst comp shifter , magnaflow axle backs,frp x-pipe, saleen pulleys,K&N cai,M&H 275/50/17 drag radials they are really sticky no spin. My car tuned at racersedgetuning Downey cal. I have stock gears 3.55s Best time before was 8.427 et. My car is a 5sp
Nice run... but I'm skeptical of the 60' time. That's lower than most people get with power adders. It may have been a timing error. What was your next best run that night?
That is the lowest 60' time I've ever seen for a NA car. Not trying to call you out but Don is right- if you pulled that time without any track errors and with only the mods you say you have, then that's pretty phenominal.
Look at mile per hour 81.09 most car would be at 88 mph . i have none 18.26 with street tires the M&Hs are best tires .I have done 18`s with slipping the clutch this time i dumped the clutch at 5000 rpms the tires gripped with a little spin at the start raising the front end, and off i went . The water box was not wet no burnout either. I cleaned my K&N air filter for the first time since i installed it 1 1/2 years ago last week ,now i`m runnig 8.4 slipping the clutch so i tryed dumping the clutch .
roushcollection
7/28/15 02:08 PM
