Bassani catted xpipe install advice
Old Jan 13, 2006 | 01:43 PM
jwgroovin's Avatar
We rolled the Mustang up on the Rhino ramps to get a lay of the land underneath, and the only tricky part we see is getting the one O2 sensor off closest to the manifold. There really wasn't enough room under there with the ramps, so we're going to put it up high on the jacks tomorrow, assuming it stays dry here in MD. Any advice or known gotchas, especially getting to that one 02 sensor? Thanks.
John
Old Jan 13, 2006 | 01:48 PM
don_w's Avatar
If I recall correctly, we unbolted the stock exhaust pipe connection at the manifold and let the cat drop down slightly. There was enough give in the O2 sensor wire that we could get it off then.
Old Jan 13, 2006 | 02:13 PM
tom281's Avatar
I just removed my factory H and installed the Pypes H on Wednesday night; total R&R time: 1 hour. Used ramps and jacks.
As far as the sensors, I unplugged each one (including the one closest to the engine) at their harness connections. This way, I dropped the whole assembly and then R&R'd the sensors into the new pipe. You will find harness connections beside each sensor; for the top sensor, the harness connection is above the transmission housing.
Thanks,
tom281
Old Jan 13, 2006 | 02:31 PM
jwgroovin's Avatar
Thanks to Don and Tom for their suggestions. I'm psyched for tomorrow...
John
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
haitham
Sep 8, 2015 12:52 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
