axle-back adjustment
Sorry if this has been discussed before. I installed the FRPP (Borla) axle-backs a couple weeks ago and the tips are not quite lined up. The drivers side looks about right...centered in the cutout and sticks out about .75-1" The passenger side is riding a little bit higher, which shouldn't be too hard to fix by tweaking the hanger, but it is recessed in the cut-out, pretty much flush with the top edge. I was thinking about adjusting the length at the mid-pipe. It looks like the mid-pipe doesn't slip over the H-pipe, but is just butted up and held with a broad clamp about 4" long. Is it OK to slide them apart an inch or so and re-clamp??? Wondering if anyone else has had this problem and if so, what was your fix? Thanks.
jb
jb
9/24/15 08:15 PM
9/16/15 06:44 PM
9/10/15 12:44 PM
