Autocross / Solosprint tire size
Old Jun 7, 2006 | 11:07 AM
HolyPony!'s Avatar
Hi all, I am looing for DOT race tires for solosprint and can't find anything listed in any size that's close to the stock diameter... Anyone has some ideas ? What do you use ? I have to buy wheels, so 17" or 18" will do...
Thanks !
Old Jun 7, 2006 | 02:00 PM
HolyPony!'s Avatar
I found the Falken Azenis RT-615, size 255-45-18 which has the same diameter, has anyone experienced this size ?
Old Jun 8, 2006 | 08:03 AM
05BlackGT's Avatar
Why do you need to have the stock diameter? I run 275/40/17 Kuhmo V710s. Everybody in my class runs this tire in various sizes.
Old Jun 8, 2006 | 08:58 AM
HolyPony!'s Avatar
I thought you had to have more or less the same diameter for ABS and the various TCS sensors (obviously the speedo is not a concern). Thanks for your help !
Old Jun 8, 2006 | 09:17 AM
05BlackGT's Avatar
If you have an SCT tuner, you could enter the different tire size. I've done this, but didn't notice a difference, so I don't bother with it anymore. Also, if your ABS is kicking in frequently, you might be braking too hard, too late. As for the TCS, I now keep a post-it on my steering wheel while at the track that says "TURN TCS OFF!". When I forgot to turn it off, my times would be almost a second slower.
Old Jun 8, 2006 | 10:39 AM
HolyPony!'s Avatar
Great stuff thanks for the info
Old Jun 8, 2006 | 08:15 PM
Stoenr's Avatar
mmm autocross, enjoy!
Intense stuff, makes drag racing feel like a Sunday drive
Old Jun 21, 2006 | 08:02 AM
softbatch's Avatar
I talk to cones.
That and using that size is like putting on a set of 3.73 gears, don't worry about the ABS since you'll only be using them on an Autocross course, also you should have TCS turned off when you run.
14BlackGT
Aug 26, 2015 12:33 PM
JonathonK
Jul 27, 2015 07:35 PM
