Another Hurst Shifter install question.....
Old Aug 28, 2005 | 07:38 AM
  #41
Stoopy's Avatar
My car was built July 27, just a week or two before the end of '05 production, and has the two "half" metal bushings that go in from each side to make one bushing with shoulders on each side, like Vegasjay.
Old Aug 28, 2005 | 10:42 AM
  #42
S197 GT's Avatar
3rd Times A Charm
Thanks for all of these updates on the shifter. I felt one at the Good Guys car show yesterday, and it WILL be my next mod.
Sorry to highjack, but does anyone have the picture of the "Hurst Equipped" emblem installed on the dash? I think I saw Davids2Toys, but I can't find it now. Also, does the emblem come with the shifter? Where are you guys getting them the cheapest. I found it for $219.00
Old Aug 28, 2005 | 11:04 AM
  #43
GRAYPNY's Avatar
Hi Nick,
You can get the shifter from LM Performance for $215 shipped and here is a link for the Hurst equiped emblems.
http://www.jegs.com/cgi-bin/ncommerce3/Pro...617&prmenbr=361
Old Aug 28, 2005 | 12:01 PM
  #44
Vegasjay's Avatar
I bought mine through LM Performance, and they had the emblem's also ($9.95).
Old Aug 28, 2005 | 03:41 PM
  #45
S197 GT's Avatar
3rd Times A Charm
Thanks a lot guys. I should be getting one within a few weeks. Hopefully with some powder coated cam covers.
Old Aug 28, 2005 | 08:20 PM
  #46
hawgman's Avatar
There are several on ebay for less. Some are set up for the stock shift ****, some with the chrome shift handle and classic ****.
Old Aug 28, 2005 | 10:03 PM
  #47
Eleanor Dreaming's Avatar
I got mine from e-bay, also ordered a black ball. Haven't received either yet. Should be this week.
Old Aug 29, 2005 | 12:35 PM
  #48
Shea's Avatar
For the guy that started the thread (and everyone else), I heard that to go into reverse you have to push the stick left of neutral, then right and back. Wondered if everyone knew this, it is supposedly in the owner's manual.
My car isn't here yet, so I can't verify.
Old Aug 29, 2005 | 11:15 PM
  #49
Redfire 05Gt's Avatar
Anyone know anyone who's tried the new B&M shifter yet?
Old Aug 30, 2005 | 09:26 AM
  #50
Stoopy's Avatar
Thanks - actually, I tried and for me, that doesn't do anything for this trans. However, the old tried-and-true trick of pulling it down into second gear, then up and over into reverse works very well - as it does with most sticks. Goes right in smooth as can be.
Oh.....and after two days of driving around after my re-work above, my conclusion now is: the overall change (half-baked reverse install vs. by the book) is not worth it, it's better to just install the thing like the instructions say. It felt much better sitting in the garage, dry-shifting it, but once on the road and moving, it's the same. Go figger......
I do believe tho, that the notchiness is not from the stick but from the trans, and I have also noticed that shifting from higher revs, it's much smoother. Not surprising if it's just a matter of waiting for the synchro's to do their job, and a matching RPM for the next gear is reached quicker. So, this is a GREAT stick for the strip and for spirited driving. Cruising and more mellow everyday driving take a little different touch. I'm putting the setup back to the way it was (per Hurst) next weekend, then am done with it.
Would be interesting to see how the B&M stacks up. If they use a less aggressive pivot point it could be smoother but with more travel, or maybe if they use a more forgiving bushing material. I keep wondering what the Hurst unit would be like with the stock rubber bushings instead of the poly ones.....obviously I need to find something else to occupy my mind and just start driving around enjoying it.....
Old Aug 30, 2005 | 03:31 PM
  #51
S197 GT's Avatar
3rd Times A Charm
So how is this shifter going to be for us that do not have a tune. I KNOW YOU DON"T NEED A TUNE FOR THIS OBVIOUSLY. But with the throttle lag, Do you still have to wait forever for the synchros to match up?
Old Sep 2, 2005 | 10:26 AM
  #52
davids2toys's Avatar
[quote=Vegasjay,August 27, 2005, 6:20 PM]
Originally Posted by davids2toys,August 27, 2005, 1:14 AM
I only had 1 metal bushing, it had a shoulder on 1 side and did NOT go the full length of the bushing, almost though, was short about an 1/8th of an inch! I did call Hurst about this after I did the install and they said it did not matter, the guy really did not have a clue and he was a tech!!! So as of right now I am running with 1 metal bushing and 2 plastic bushings.
Justin, could it be you got an early car and I got a June car, maybe they changed the type and quantity callout if the bushing used. So how far does each of your metal sleeves reach into the bushing?
Yes, my car was one of the first (#744). My two metal bushing's contact eachother in the middle making the metal bushing solid going all the way through the poly bushing. They also have an 1/8" solid lip on the ouside of both side's of the poly bushing... In other word's the two metal bushing's are identical and insert in the opposite side's of the poly, meeting in the middle to form a solid bushing. I'm not a Hurst "Tech" but I can't see how that bushing not going all the way through couldn't have adverse affect's on shifter feel. When you tighten that 10mm bolt into the tranny without a full length metal bushing in there, it would allow the poly bushing to deform and deflect. I would be curious to see what the Ford part's book calls for on the bushing's, if there was a redesign etc. I would ask KC the part's guy on here to check it out. I just want your Hurst to feel as good as it can Dave. I think your bushing may be the culprit...
Talked to Kevin yesterday, it does not call out any bushings at all, just the bolt, he is going to order one and see if it comes with bushings!
I am going to pick up the nuts today to double nut the attach point, I may grab a big washer and install it on the front where I only have 1 long metal sleeve...hopefully this will serve as a shoulder for the poly bushing so it wont deform. :bang:
Old Sep 2, 2005 | 10:27 AM
  #53
Stoopy, I like your idea of double nutting it...i am going to try it
Old Sep 6, 2005 | 04:42 PM
  #54
05stangkc's Avatar
Ford has A Cataloging Issue on the Bolt Kit. Mispackaged! or Miscataloged. Still working on it! There appears to be a Bushing on the Bolt in the 2006 Catalog. Can anybody get me a pic of both shifter arms and bolts so I can Have some ammo to get Ford Straightend out!
kc
Old Sep 6, 2005 | 08:39 PM
  #55
I hope to be back under there within a week...I have no pictures at the moment.
Old Sep 6, 2005 | 09:03 PM
  #56
Stoopy's Avatar
Well, I just looked at my photos again and I have tosay - I'M STUPID!
Turns out I DIDNT have two halve-sleevs in the front bushing, but instead, one sleeve that went the whole distance, with just one shoulder. The below picture proves it. You can clearly see there is no shoulder on this side. And I now recall tapping the thing out all the way from one side only, with a socket slightly smaller!
I've no idea why I thought there were two....and moreover I'm not sure it matters anyways.
Old Sep 6, 2005 | 09:15 PM
  #57
KC, will this pic that stoopy sent help you with ford???
Old Sep 6, 2005 | 09:17 PM
  #58
So Stoopy, is this why they call you STOOPY...lol
Old Sep 6, 2005 | 09:32 PM
  #59
Stoopy's Avatar
Heck, thats even why I call myself Stoopy, are ya kiddin' me??!! LMAO!!!
Old Sep 8, 2005 | 07:39 PM
  #60
lol
