Air fuel guage
Old Dec 14, 2005 | 12:09 PM
dlc's Avatar
dlc
Puting in a autometer air Fuel guage. Wich wire is the signal wire on the O2 sensor?
Old Dec 14, 2005 | 01:12 PM
hawgman's Avatar
Good luck. I posted the same question and all I got was responses telling me they were not accurate and I needed to install a wideband.
Old Dec 15, 2005 | 06:37 PM
...'s Avatar
At the Powertrain Control Module:
50pin black plug.
Pin 24 (red/light green)
or
Pin 25 (violet/light green)
Heated Oxygen Sensor signal wires.
Old Dec 15, 2005 | 06:53 PM
hawgman's Avatar
Which 50 pin black plug? There is more than one. I do see a violet / light green wire in the top plug ( same plug with the VCC wire ), is that the correct one?
Old Dec 15, 2005 | 11:05 PM
...'s Avatar
that sounds like it..it's the upper plug.
Old Dec 16, 2005 | 07:21 AM
hawgman's Avatar
Spanks man. Much appreciated. One last annoying question. Any idea which sensor (s) this is for? Pre or post cat?
Old Dec 16, 2005 | 08:25 AM
...'s Avatar
pm me your email and i'll send you over the diagrams (in pdf)
Old Dec 16, 2005 | 10:09 AM
hawgman's Avatar
You have PM.
As a side note. I just tried both wires. The A/F gauge needle will jump when you hit the starter. Then will go dead for about 5 minutes. Then it starts working. Would think it has something to do with the cats being heated before the sensors operate. But it also does it after driving, turning the car off for a minute, then restarting.
But anyway, either of those two wires will do what they need to.
Thanks again for the help.
Old Dec 28, 2005 | 11:04 AM
thestoogeo's Avatar
Does anyone have any photos? PDF's?
Jon
Old Dec 28, 2005 | 11:06 AM
thestoogeo's Avatar
Is it normal for the gauge to not work until after 5 minutes? Will buying a seperate O2 sensor be a better idea?
Jon
Old Dec 31, 2005 | 01:58 AM
thestoogeo's Avatar
I was looking around and found a photo showing the O2 sensor wire to splice into:
[attachmentid=41917]
Thanks hawgman.
Jon
Old Nov 17, 2007 | 06:43 AM
91svtcoupe's Avatar
bring up an old thread.....
I am doing this very thing....good idea? anyone let me know thanks Rob
Old Nov 17, 2007 | 09:05 AM
qwik huh's Avatar
I just installed one last week. I used Pin 28 in the powertrain conrol module. It is a gray wire with a light blue stripe. The gauge works perfectly which means the lights dance and that is about all it is good for.
Old Nov 17, 2007 | 03:08 PM
06GT4RAD's Avatar
I have this picture. Supose to be good info I got it elsewhere. That is the first plug at the ECM
Richard
Old Nov 17, 2007 | 03:33 PM
max2000jp's Avatar
No offense, but why waste your time installing this. Throw it up on Ebay and buy a Wideband.
Old Nov 19, 2007 | 06:43 AM
uberPony's Avatar
Autometer makes nice wideband for the Cobalt and nexxus series gauges.
Mar 30, 2021 09:29 AM
Cobiecane
Oct 23, 2015 08:44 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Earlsays
Sep 12, 2015 06:29 PM
