After Market Battery??? Opinions...
Old Jan 7, 2010 | 04:22 PM
PIKE2244's Avatar
Looking at replacing my stock battery and what to know what is a better choice for replacing it??? Is there a lighter battery I can use? Thanks guys; and Always APPRECIATED!!!
Old Jan 7, 2010 | 07:20 PM
Green96GT's Avatar
OPTIMA!!!!! yellow top
Old Jan 8, 2010 | 06:36 AM
PIKE2244's Avatar
Thanks for the help!!!
Old Jan 8, 2010 | 07:48 AM
gremlin190's Avatar
What is soooo much better about the optima batteries????
Old Jan 8, 2010 | 10:39 AM
PIKE2244's Avatar
I need to replace it anyways so why not w/ something lighter...
Old Jan 8, 2010 | 12:14 PM
Starfire's Avatar
Are they really that much lighter, I was going to get one, till I looked at summit it it's weight is 38LBS. I got a walmart one, there actually rated pretty good, think they are made by the same company that makes optimas if I remember.
Yellow top is even more 44lbs
Old Jan 9, 2010 | 10:09 AM
Wharf Rat's Avatar
Interstate or Optima
Old Jan 9, 2010 | 11:45 AM
PIKE2244's Avatar
So what battery did you actually get??? Name?
Old Jan 9, 2010 | 11:59 AM
NastyStang113's Avatar
I hate to be the bearer of bad news. The Optimas are not lighter than OEM. They are actually heavier than the factory battery. I replaced my OEM battery with an Optima Red Top and it's definitely a few lbs heavier. If you want a lightweight battery than you need to look into Deka. Deka and Braille (Very Expensive) are the same thing. Here's a good thread with information.
http://s197forum.com/forum/showthread.php?t=18503
Optima uses "Spiralcell" technology which is better and offers more power.
http://www.optimabatteries.com/optima_products/
Old Jan 9, 2010 | 12:01 PM
MadGT's Avatar
Legacy Tms Member
heard many good things about optima.
Old Jan 9, 2010 | 12:12 PM
Ministang's Avatar
Look at Odyssey batteries. Many models are lighter than stock, I've had them inseveral cars in the past, I have one in my Miata now, and plan to get them for one or both of my Mustangs this year.
Old Jan 9, 2010 | 02:22 PM
cme82's Avatar
FWIW I have an optima in mine. I chose it not for the weight but the fact its a maintenance free AGM battery. I work at a m/c shop and Harley's AGM batteries are some of the best batteries we've found. Last well over 5 years and actually put more CCA's than most of the high output "gel" batteries. They are miles ahead of any "wet" batteries, at least on bikes. Hoping I have a similar experience in my car.
Old Jan 9, 2010 | 04:18 PM
JedCranium's Avatar
I found this to be true so what I did was I bought the highest output Optima with the smallest footprint.
Old Jan 9, 2010 | 04:19 PM
MARZ's Avatar
Swamp Donkey Aficionado
Another Optima vote here, too.
Old Jan 9, 2010 | 05:49 PM
70MACH1OWNER's Avatar
Last year I needed a new battery and reviewed all of the above possibilities. I decided to put the stock Motorcraft back in her for $100 bucks. It fits the battery tray and the tie downs plus the heat blanket. Also it had a 3 yr. free replacement warranty. Everything fit with no modifications. All other choices had issues. Even the Optima's.
Old Jan 9, 2010 | 08:19 PM
Stoenr's Avatar
Interstate is the way I went, same fitment as the ford OE, little better warranty, and I get them at cost, lol. (Well did)
Old Jan 9, 2010 | 09:09 PM
karman's Avatar
I prefer Interstate too.
My dad's last one was good for over 8 years.
I told him back then that they lasted well.
Old Jan 10, 2010 | 08:42 AM
topoffGT's Avatar
Will the small difference in weight really be noticeable? I hope the 5 lbs. I gained over the holidays doesn't hurt the handling of my Mustang!
I got a red top Optima. It really spins the starter fast with 800 cranking amps.
Old Jan 10, 2010 | 11:38 AM
1fastbob's Avatar
Stick with a name brand battery and you will be good. Optima batterys are great, but they are also pretty pricey.
Old Jan 10, 2010 | 12:08 PM
Darth Stang's Avatar
I went with the WalMart duralast for $43 bucks. A little better than stock on CCA and warranty to boot! Highly recommend to replace OEM at reasonable cost.
