Is an adjustable UCA necessary if I am not lowering the car?
Old Mar 2, 2007 | 06:28 PM
Jon_Purdy's Avatar
Is an adjustable UCA necessary if I am not lowering the car? I ask because I've decided against lowering the car as I am quite happy with the stock ride height and ride quality.
Jon
Old Mar 2, 2007 | 07:20 PM
06GT4RAD's Avatar
Not unless you plan on getting a 1 Piece drive shaft and even then it is up for debate. If you plan on getting a piece driveshaft then i would suggest it simply to make sure the pinion angle is correct. And although ti should be ok in stock form it may need some minor tweaking and the UCA will allow this.
Richard
Old Mar 7, 2007 | 02:57 PM
likemike99's Avatar
even if you are going to change the pinion angle I would recomend the lower control arms . they have much more flex than the upper. so upgrading them reduces the flex, allows the adjustments and is easier to adjust due to their location.
Old Mar 7, 2007 | 03:16 PM
thump_rrr's Avatar
If you are experiencing wheelhop then the uca replaceent is worthwhile. If you plan on dropping the car in the future then get the adjustable UCA.
Ecostang
Nov 3, 2022 08:50 PM
SMBJoshy
Aug 24, 2015 10:55 AM
09-gt/cs
05-09 Exterior Modifications
Aug 2, 2015 10:08 AM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
