5.0 stroker tune problems
Old Dec 13, 2014 | 07:54 PM
vlh007's Avatar
I just joined this site and am excited to be here. But I'm already asking for help. My 2005 GT has a fresh 5.0 stroker motor with whipple 2.3 pushing 11.5 psi. I had the car dyno tuned at Archangel Motorsports in Tulsa OK and it's putting out 530hp at the tires. Runs great when the motor is at full operation temp, but stumbles bad when cold. the stumble (lean) slowly goes away as the engine heats up. You guys think it's a sensor problem, or a tune problem? And you can count Archangel out, they will not answer the phone, emails, facebook messages, smoke signals, nothing, no customer support whatsoever!!!!!
Old Dec 14, 2014 | 04:15 AM
dly's Avatar
dly
Check out Brenspeed in Texas they might be able to help out. I've use their home shop here in Indiana with great succes.
Old Dec 14, 2014 | 01:06 PM
shayner's Avatar
I'd say it's your tune. Just a question... Do you have a return fuel system on the car?
Seems to me you should be Able to have some really good power from a stroker setup. 530 rwhp is very mild.
What type of injectors do you have?
Old Dec 14, 2014 | 10:03 PM
vlh007's Avatar
injectors are bosch EV-6 60lb. The original owner of this car installed a ford motorsports 500hp supercharger kit that included the whipple and gt500 fuel pump, so I guess no fuel return system. I added the stroker kit, cams, long tubes, injectors, MAF. I think the tune is mild with mild timing, 19 degrees I think.
Old Jan 3, 2015 | 12:36 PM
anthony05gt's Avatar
That whippled stroker will never run smoothly until it's warmed up reguardless of who tuned it. Nature of the beast unlike a centri blower which doesn't dump so much air at low R's.
Old Jan 3, 2015 | 02:35 PM
shayner's Avatar
Have to agree !!!
Good point Anthony
Old Jan 3, 2015 | 02:37 PM
I didn't know that. I would have thought an issue with MAF, O2 sensors not being able to adjust properly.
Old Jan 4, 2015 | 07:48 AM
No, you have to figure that Whipple is really changing everything even right off idle. It takes a lot of tweaking the tables in the pcm to work out all the snags the blower and injectors cause and when the engine is cold it changes everything. Not only that, as the engine warms it's never the same temperature during the warm up. I'm not a tuner, but I'm sure a good tuner could try to smooth some of that, but he would need to adjust things during multiple cold starts and I don't even know if that's possible.
Old Feb 15, 2015 | 09:33 PM
vlh007's Avatar
this car did not have these issue with the whipple till I installed the 60lb injectors and bigger MAF. Now car is a nightmare
Mpaps
Oct 11, 2017 08:06 PM
Cdvision
Sep 5, 2015 05:22 PM
Kestral
Sep 2, 2015 06:52 PM
