-   GT Performance Mods (https://themustangsource.com/forums/f669/)
-   -   4 Piston Brake Calipers (https://themustangsource.com/forums/f669/4-piston-brake-calipers-552034/)
rocknrod Jun 11, 2025 06:44 PM
Why wouldn't these 4 piston brake calipers fit on my 05 GT? I have GT500 18" wheels installed.
https://a-premium.com/product/2-Pcs-...ang-joNdYra3Ld
Some even less expensive units - https://www.carid.com/2007-ford-must...-45332327.html
Rotors - https://www.carid.com/2007-ford-must...-20673917.html
Rear Rotors 13.98" - https://www.carid.com/2013-ford-must...-20346738.html
The reason I ask is I just replaced all four rotors and pads, drilled rotors and ceramic pads - It is still embarrassingly slow to brake. :(
https://cimg9.ibsrv.net/gimg/themust...6aee647a8d.jpg
05stangkc Jun 11, 2025 09:05 PM
Before Giving Up on What You Installed Did You Bed In Brakes after Install??
https://www.autozone.com/diy/brakes/bedding-brakes
KC
rocknrod Jun 11, 2025 09:17 PM
That's exactly how I did it.
05stangkc Jun 11, 2025 09:39 PM
4 Attachment(s)
Gotcha! Just Thought I Would Check!
The Calipers in The First Kit You Showed are Basically Replacements For the Gt-500 Calipers.
Here is The Ford Kit To Upgrade To Gt-500 Brakes. You Could Piece it Together & Save Some Bucks. The Pdf Would Be Good To Review For Consideration.
You Do Have The Right Wheels!
On a Side Note I Made Up A Kit For This very Same Deal Before Ford Racing Way Back! 19 Years To Be Exact! But Of Course Once They Had it My Pricing Went to Hell!
https://performanceparts.ford.com/part/M-2300-S
rocknrod Jun 12, 2025 06:10 AM
Alright, thank you for that info. :nice:
Bert Jun 16, 2025 12:14 PM
those look like Brembo knock-offs or maybe remanufactured Brembos
yes they should clear the 18" GT500 wheels -- they are the same brakes that the GT500's had
I am not sure about the upsized rear rotors, I believe they will fit inside 18" wheels but not positive (they were used on the later GT500's that had 19" wheels)
another way to get improved brake pedal feel is braided stainless lines
rocknrod Jun 16, 2025 02:23 PM
Thanks Bert good info. :nice:
Bert Jun 16, 2025 02:26 PM
here are kits available from LMR; I see some of them are "out of stock" https://lmr.com/products/05-09-Mustang-Brake-Kits
I believe this is the kit that I used on my 2010 and it worked out great; though the price has gone up a bit since I did it several years ago. I also added the upsized rear rotors, using a bracket available from a guy on e-bay, since this kit does not include the upsized rear rotors
https://lmr.com/item/M2300S/Mustang-...e-Kit-M-2300-S
rocknrod Aug 5, 2025 12:37 PM
I wonder if the booster isn't getting the vacuum it needs. Maybe something along these lines will do the trick - https://www.studiohotrods.com/produc...rv3zGg523KWdBw
05stangkc Aug 5, 2025 01:31 PM
Altough The Op's Problem Ended Up Being a Misrouted Catch Can Setup I Posted a Lot of Brake Booster Related Info Which You Might Gleen Some Idea's From. Also a Very Inexpensive Vacuum Pump From a FORD DIESEL is Listed.
https://themustangsource.com/forums/...ooster-550482/
KC
