373s what do i need
Old Feb 8, 2012 | 12:54 PM
muscledom's Avatar
373s what do i need
Gears, install kit, gear lube. Anything else? Tips? Hints?
Old Feb 8, 2012 | 01:02 PM
AlsCobra's Avatar
A Man Just Needs Some....
Setting up a rear end is not easy if you are doing it yourself for the first time. You might get lucky but it might and probably will eat your lunch. It would really be worth paying a pro to change them for you. Just my advise.
Old Feb 8, 2012 | 01:10 PM
muscledom's Avatar
Yea I don't have the ***** to attempt that lol. I work at a bhph lot with a garage so I'll have the shop mechanic do it. Any thing else that I'll need tho?
Old Feb 8, 2012 | 01:12 PM
11SHELBYGT500's Avatar
+1 some experienced mechanics even have trouble with this job
Old Feb 8, 2012 | 01:17 PM
skunk21's Avatar
Tip: Like Al stated this isn't a first timer friendly project. I have done alot of stuff on cars and didn't bother doing my rearend. I had a well known shop do my build. It seams simple enough but if it isn't done right you will get gear wine at the very least. If you don't have alot of miles on your car then I wouldn't worry about much, I used a Ford master kit and did new diff bearings, axle bearings, seals, etc. but then again my car had miles on it and I added a new diff, axles and welded the tubes. I would just get a good kit and either use your guy or find a shop, probally cost about 400 range.
Old Feb 8, 2012 | 01:24 PM
muscledom's Avatar
Cool thanks for the info guys. My 08 has 62k on it. Need anything special?
Old Feb 8, 2012 | 01:29 PM
skunk21's Avatar
doubt it.
Old Feb 8, 2012 | 01:32 PM
AlsCobra's Avatar
Make sure your kit has a diff cover gasket, shim kit, crush sleeve, pinion bearing, and pinion seal. That should cover it.
Old Feb 8, 2012 | 01:34 PM
muscledom's Avatar
Yea I think the one I was lookin at on AM had all that
Old Feb 8, 2012 | 01:36 PM
AlsCobra's Avatar
Do you have a programmer for speedometer calibration?
Old Feb 8, 2012 | 01:56 PM
muscledom's Avatar
O yea
mustangmike1039
1994-2004 V-8
Jul 30, 2014 07:53 AM
mustangmike1039
Jul 4, 2014 01:49 PM
Clark Kent
Jul 24, 2011 09:21 PM
Mtang78
12
Aug 29, 2008 08:31 AM
mustangshadow
14
Feb 23, 2007 07:20 AM
