3.55 gears for GT
Old Dec 29, 2006 | 11:11 AM
YaoNYC's Avatar
3.55 gears for GT
hi all,
what brand is best? lightest weight? price?
also, why was this not offered on auto. GT's?
thanks!
Old Dec 29, 2006 | 01:08 PM
LordBritish's Avatar
You can probably find 3.55 take offs really cheap.
But why 3.55s??
Slap in a 3.73 like I did.
The most expensive part of the swap is not the gear itself but labor (unless you're doing it yourself which I dont reccomend unless you've done it before).
Old Dec 29, 2006 | 02:18 PM
69_gt500's Avatar
why get 3.73's when you can get 4.10s
Old Dec 29, 2006 | 02:26 PM
YaoNYC's Avatar
the reason is..
i just want to get a little extra kick...nothing crazy...
so when on the highway its still very comfortable, gas mileage is good.....
also, i read some about a tuner who tested gears on auto. GT's and said 3.55 is the best...
in the future if i want to do supercharger, 3.55 will fit it fine...
YardSpecial's Avatar
Because first & second gear is insane low know.
I think 3.55 should be perfect, more so with a blower...........
Old Dec 29, 2006 | 02:34 PM
tx2005gt's Avatar
i have 3:55's that are frp. installed them my self & have had no gear wine or any other problems. they made the car feel much better & it still gets great gas mileage.
Old Dec 29, 2006 | 03:34 PM
YaoNYC's Avatar
that is exactly what i'm looking for. thanks for this information. im looking for that litte extra kick..nothing crazy
when cruising at 70 mph, what rpm are you at now? i assume before it was around 2000 rpm...
Old Dec 29, 2006 | 04:02 PM
classix_stang289's Avatar
Richmond 4:10's are great, will definitely give you that kick your looking for. If thats too much 3:73's are another great choice. You cant go wrong with either one.
Old Dec 29, 2006 | 05:26 PM
RadBOSS's Avatar
There generally is no wt. savings between manufacturers gear sets ... the ring and pinion wt. is what it is for a particular ratio ... okay there might be a few grams difference, but nothing like a pound or two.
Old Dec 29, 2006 | 05:44 PM
tom281's Avatar
I have two sets of Ford 3.55 gears for sale...... one set came from my '06 GT and the other from my '04 Mach 1. $50 plus shipping if you're interested.
Old Dec 29, 2006 | 06:18 PM
YaoNYC's Avatar
hi tom218, i'll take the set from your '06 GT for $50!!
pm me information and we can do this deal...
thanks!
Old Dec 29, 2006 | 06:19 PM
YaoNYC's Avatar
ok great..thanks for the info..
then probably staying ford is safe
Old Dec 29, 2006 | 06:37 PM
GRAYPNY's Avatar
I have a set too! I'll sell mine for the same price as Tom.
Old Dec 29, 2006 | 06:48 PM
tom281's Avatar
thanks!
PM sent...... thanks.
Old Dec 29, 2006 | 06:53 PM
inVERTed's Avatar
3.90's
do they make them ?
Old Dec 29, 2006 | 09:50 PM
habu's Avatar
3.90's... I've seen, I think on Lethalperformance, a set made by Motive
Old Dec 29, 2006 | 10:31 PM
AFBLUE's Avatar
Dethroned Nascar Guru
http://www.lethalperformance.com/pag...390-ratio.html
Old Dec 30, 2006 | 12:56 PM
tx2005gt's Avatar
i think is is about 2100 rpm. 50 bucks for a low mileage set is not bad. i liked using a new set because when you use a used set it should go back with the same backlash & rolling torque that it was set at originally. when you go new you just have to have it in spec. no matter what you do make sure that you get a new install kit.
Old Dec 30, 2006 | 05:59 PM
YaoNYC's Avatar
hi TX2005gt,
are you saying its risky to installed previously used 3.55 gear set?
thanks!
Old Dec 30, 2006 | 07:36 PM
tom281's Avatar
That doesn't make sense saying that it "should go back with the same backlash & rolling torque that it was set at originally" and that going new "you just have to have it in spec". As long as they're installed, either used or new, at the correct specifications then you'll be good to go. It almost sounds like you're implying that Ford would have different install specs for either used or new gears- which they don't.
The 4.10s that I have in my '06 GT now I bought used from a guy here last year, and the local mom & pop install shop that does all my gear installs put them in within a couple of hours and had no problems- and the car was (is) new enough that I didn't buy the $100 install kit- they just used a new crush sleeve and synthetic lube. My parts total was less than $50 if I remember right.
