2008 Mustang GT Alternator install?
Old Nov 5, 2009 | 03:42 PM
krnpimpsta's Avatar
Been looking - can't find any instructions on alternator install.. is it really simple? Anyone have instructions?
My stock alternator went out at 25k (it's 2/3 out right now.. just weak, not totally out yet), and I was told I can't get it replaced under warranty, because of all my aftermarket audio equipment.
Is this something I can do on my own, without special tools?
I'm looking at ordering a PA Performance 200A alternator online right now...
Old Nov 5, 2009 | 04:43 PM
tom281's Avatar
Yep, I know we just exchanged PMs but for the benefit of everyone here, it is a simple install.... no problems.
Old Nov 6, 2009 | 03:14 PM
krnpimpsta's Avatar
Yep - thanks Tom.
FYI ordered from here: http://dagostinoracing.com/index.php...ducts_id=13612
Old Nov 6, 2009 | 05:17 PM
tom281's Avatar
Cool beans, good luck.
Old Nov 7, 2009 | 02:07 PM
RedDragon777's Avatar
Eh i am thinking about this, i know the stock battery has had some recalls but i am having a strange feeling that it is my alternator that is not keeping my battery charged. I should be ordering my Aeroforce dual interceptors soon and i will see if i really need a new battery or a new alternator.
Old Nov 7, 2009 | 05:29 PM
MTAS's Avatar
Should be a process very similar to this:
http://iihs.net/fsm/?dir=370&viewfil...20%283V%29.pdf
I just went through this myself on my 05, it's a 20min process
Old Nov 14, 2009 | 04:39 PM
krnpimpsta's Avatar
Alternator replaced. Those instructions were great - only thing is that I also had to remove the throttle body to get the alternator off, and also had to buy a belt tensioner release tool.
Also - D'Agostino Racing shipped extremely fast. Ordered Friday, shipped Monday - arrived Tuesday.
Old Nov 14, 2009 | 05:31 PM
tom281's Avatar
awesome!
Old Nov 14, 2009 | 07:31 PM
Did you buy the 200 amp or the 130? If you bought the 200 did you do the wire upgrade or just plug-n-play with the old wire
Old Nov 14, 2009 | 08:00 PM
krnpimpsta's Avatar
The 200A.
The wire upgrade is manditory with the 200A - and if you buy from the link in my earlier post, you get the wire with the alternator.
It's essentially still plug and play: You leave your old wire in, and still plug it into your new alternator. The new wire you run IN ADDITION to the old wire, straight to the battery. That way, you have: double the wire to run more current / less resistance/heat. Also it may save you if you have warranty issues, because your stock wiring is still intact.
Old Nov 14, 2009 | 08:01 PM
I'm hoping he upgraded the wire to the 4 ga.
It is extremely important to upgrade the alternator wire. And I'd upgrade the ground from the battery to the chassis too. Well at least that's what I did.
Edit: NVM
Old Jun 25, 2010 | 04:29 PM
prpilot's Avatar
Exclamation
I also had to remove my throttle body. Probably good thing to clean it now anyway.
BTW, you can use a 1/2" socket wrench to release the tension on the belt tensioner. It just goes right in. No need to buy the tool from Ford.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
SMBJoshy
Aug 24, 2015 10:55 AM
