12v Switched Source
Old Nov 27, 2007 | 08:10 AM
Sharky's Avatar
12v Switched Source
Anyone have a sure fire location for an EASY to get to 12v switched power source. I am about to install a purge kit to my NOS system, it seems that everything in the fuse box is constant on. So is there a wire I can splice to or a fuse i can tap to get a 12v source that goes cold with the key?
Old Nov 27, 2007 | 08:28 AM
steph's Avatar
try the stater solonoid.
Old Nov 27, 2007 | 11:14 AM
mot250's Avatar
I can't remember what the number is off the top of my head but this one works for my electric water pump... the one diectly under the tap in the picture below...
Old Nov 27, 2007 | 11:39 AM
Sharky's Avatar
Thanks!
Old Nov 27, 2007 | 06:01 PM
mot250's Avatar
Originally Posted by Sharky
Thanks!
You're welcome!
Update, the one under the tap is # 42 that I used and is "live" when the key is "on".
Fuse # 40 on the other side of the center bolt of the fuse box (fuse with the red wire going over top of it) is "live" only when the engine is running.
Your choice...
Old Jul 18, 2025 | 07:12 PM
VGMStudios's Avatar
Tms Mustang Member ------ The Customizer!
You're welcome!
Your choice...
I know this is an old thread but want to provide proper info cause this post confused me for a second. The fuse with the red wire going on top of it is fuse #43 Alternator.
Fuse #40 is right above fuse #42.
