12.01 at 115, NA
Old Oct 18, 2010 | 04:54 PM
jwgroovin's Avatar
12.01 at 115, NA
Almost got the car into the 11s NA. Weight is 3440 with me in it (I'm 165) and the usual bolt ons and cams. Car #24...
Old Oct 18, 2010 | 05:14 PM
70MACH1OWNER's Avatar
That is awesome!!!
Old Oct 18, 2010 | 05:17 PM
Old Oct 18, 2010 | 05:52 PM
fdjizm's Avatar
Nice runs man!!
Old Oct 19, 2010 | 05:04 AM
Scott2's Avatar
Great runs. Good luck on your NA quest for 11's.
Old Oct 19, 2010 | 05:37 AM
tom281's Avatar
Great 60' time! Very nice!
Old Oct 19, 2010 | 06:01 AM
forensicsteve's Avatar
Terrific
what did you do to lose 200lbs or so from stock weight?
Old Oct 19, 2010 | 08:39 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
What kind of tires are you using? Launch rpm?
Old Oct 19, 2010 | 11:47 AM
Five Oh Brian's Avatar
Nice times, but I'm really surprised that you didn't get into the 11's. Our cars are nearly identical on the timeslip, yet I ran into the 11's at our local track this past weekend. You had a better 60' and higher trap speed than I, so it's weird that you didn't go 11's??? Here's my slips from this weekend to compare against....
Old Oct 19, 2010 | 06:12 PM
jwgroovin's Avatar
Originally Posted by forensicsteve
Terrific
drag seats, no rear seats or seatbelt gear, tubular kmember and a-arms, 15" lightweight drag wheels, skinnies, etc...weighed at MIR a month or so back...
Old Oct 19, 2010 | 06:14 PM
jwgroovin's Avatar
MT ET Streets (26"x11.5/15) at about 6000rpm. I'm launching at 6500 next weekend--to hell with my clutch. This hovering at 12.0x for two months now.
Old Oct 19, 2010 | 06:18 PM
jwgroovin's Avatar
Well, you have an auto and supercharger, so the powercurves are likely just a bit different! Plus, I'm NA with a five speed, hovering at about 350hp. Next weekend I'm trying a track closer to sea level with air temps about 8-10 degrees cooler (Cecil County Dragway, MD).
Hooked well too, obviously:
Old Oct 19, 2010 | 09:33 PM
Auto vs manual, yes. Just a basic non-cooled blower, though, that put down 364 rwhp last time on the dyno (just 14 more rwhp than you). My car is about 200 lbs heavier, so the 14 extra rwhp is a wash. Powercurve is different, true, but I have no low end torque (303 rwtq) and doesn't torque win races?
Your car is definitely fast for being N/A. Must be the time off the gas for upshifts that's the difference between our cars' timeslips.
Old Oct 19, 2010 | 09:41 PM
5pointoh's Avatar
What kind of aftermarket intake and cams do you have?
What are you running for your exhaust?
Those are some nice numbers!
Old Oct 19, 2010 | 10:01 PM
Yeah it is!!
Isn't it correct the centri's take time/rpm's to build HP? (sort of like a turbo vs a blower...)
I've been watching the Pro Mods on espn and one guy has a turbo vs some blown and some nitrous. He has won a couple of races against both configurations - but just barely. That turbo finally kicks in and he slingshots the other guy right at the finish.
Isn't a centri similar?
Old Oct 19, 2010 | 11:25 PM
Originally Posted by cdynaco
Yeah it is!!
In theory, you're correct. Similar powerbands - turbo and centri. However, my car seems to buck the trend (likely the big stall converter and 4.10 gears, though). The OP's car launches hard like mine (actually, slightly better 60' time than mine), and he traps higher than me (115 mph vs 114 mph). So, he launches harder and finishes faster, leaving the middle of the track to explain why I get into the 11's and he doesn't (yet). His car is plenty fast and impressive, so it's just a matter of time until he nails 11's most every pass.
Old Oct 20, 2010 | 05:52 AM
jwgroovin's Avatar
EXACTLY! We're stumped, but it is likely to be the 2-3 shift. I really need to data log and see what happens to rpm in between shifts. The shift light is at a high 6800rpms (wait, I THINK it is, time to check before Saturday!) so they shouldn't be dropping below the power curve. Or the car is pulling timing (we thought we'd dialed that out, but maybe not). The 12.01 came after improving the 1-2 shift, and that dropped me from the 12.19 previous best. I love rowing the manual's gears!
Old Oct 20, 2010 | 03:51 PM
jwgroovin's Avatar
Here's the complete mod list:
-Exhaust-
Mac axleback muffler
JBA h-pipe
JBA titanium coated longtube headers
-Engine-
C&L cold air intake with custom SCT XCAL2, 93 octane
Comp Stage 127500 cams, springs, limiters
Steeda underdrive pullies
C&L Intake Manifold
-Drivetrain-
Stock clutch and flywheel
Spydershaft Aluminum driveshaft
Metco front driveshaft loop
FRPP 4.30 gears
Detroit TrueTrac
MGW shifter
-Suspension-
BMR strut tower brace
BMR boxed lower control arms and relocation brackets
BMR adjustable upper control arm
BMR tubular k-member
BMR radiator support/front swaybar delete bracket
BMR Xtreme Antiroll Bar
BMR Panhard Bar
BMR tubular a-arms
QA-1 adjustable race shocks
Steeda sport springs
-Wheels and Tires (Track)-
15" Bogart Drag wheels (15x4.5", 15x9.75")
Mickey Thompson 26x11.5-15 and 26x4.5-15
-Interior-
Autmeter DPSS stage 2 shift light
Autometer water temperature gauge
Innovate wideband A/F meter
Rear seat delete
Lightweight Corbeau seats
Old Oct 20, 2010 | 05:25 PM
Who's heads? Missing from your line up. For a manual guy you must be a **** good shiftman. I am an auto guy also and it is hard to believe anyone could shift a manual as fast but you my man are getting real close!!
Old Oct 20, 2010 | 06:04 PM
tom281's Avatar
With the gears/tires you must be shifting into 4th shortly before the finish? I was with manual, 4.10s, and 325/17 drag radials. That extra shift could be slowing you down just enough (for now).
