11s NA soon?
Old May 11, 2010 | 05:52 PM
jwgroovin's Avatar
11s NA soon?
Ran two 12.19s at 111 (1.588 60ft) on Sunday at Mason Dixon in Maryland. Once I get the clutch replaced I think 11s will be pretty easy. Getting this C&L manifold tuned just right with the cams has been tricky, but we ran on the old tune and got 12.40 and couldn't break it, uploaded the new tune and I had SIX personal bests that day. Will likely need decent air too so I'm looking for a morning or evening run next. May have money to pull the seats and put some lighter weight replacements in there too. Every little bit helps...
Old May 11, 2010 | 06:03 PM
Old May 11, 2010 | 09:26 PM
Americanboy86's Avatar
That's really impressive, sounds like some great driving! What mods are you running?
Old May 12, 2010 | 08:53 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Strip that thing down! Power/heated seats(if you have them) weigh a ton and you can lose a bunch of weight there.
Old May 12, 2010 | 10:17 AM
RedDragon777's Avatar
If your mod list in your sig is correct then i wonder what a built short block would do for you. Do i see 10s on a NA motor?
Old May 12, 2010 | 10:32 AM
jwgroovin's Avatar
I don't THINK anyone hit 10s with a gutted built 4.6l. I know Ron Leonard did with an NA built 5.4L. JDM got like 11.1 or 11.2 last year I think.
Here are the mods. I AM getting rid of the seats, and also finishing off my drag suspension with BMR's coil over kit for the front, with 225# springs.
-Exhaust-
Magnaflow axleback muffler
JBA h-pipe
JBA titanium coated longtube headers
-Engine-
C&L cold air intake with Woodbine Motorsports tune
C&L Intake Manifold
Comp Stage cams and beehive springs (#127500)
Steeda underdrive pullies
-Drivetrain-
Spec II+ clutch
Spec steel flywheel
Spydershaft Aluminum driveshaft
Metco front driveshaft loop
FRPP 4.30 gears
Detroit TrueTrac
MGW shifter
-Suspension-
BMR strut tower brace
BMR boxed lower control arms and relocation brackets
BMR adjustable upper control arm
BMR tubular k-member and a-arms
BMR radiator support/front swaybar delete bracket
BMR Xtreme Antiroll Bar
BMR Panhard Bar
QA-1 adjustable race shocks
Steeda sport springs
--Wheels and Tires (Track)-
15" Bogart Drag wheels (15x4.5", 15x9.75")
Mickey Thompson 26x11.5-15 and 26x4.5-15
Old May 12, 2010 | 12:41 PM
2kanchoo's Avatar
If anyone will get 10's with a na 4/6 it will be matt d. I don't think there's anyway to do it without gutting basically the entire car + every weight reduction mod out there.
Old May 12, 2010 | 01:23 PM
SONICBOOST's Avatar
Thats pretty impressive!
Old May 13, 2010 | 03:42 PM
PIKE2244's Avatar
That's Really impressive considering the Mods!!!! I am getting a little head & Cam Work done by Tomorrow so I want the real performance on the Track....
V6 Driver
Sep 8, 2013 06:08 PM
Steve@CJPP
Jun 21, 2012 06:23 AM
jwgroovin
Nov 14, 2011 03:29 PM
jwgroovin
Nov 29, 2010 08:31 PM
