Using Paint Scratch Touch-Up Paint with Langka
Hello everyone!
Just curious, has anyone else out there used Paint Scratch Touch-Up Paint with Langka Blob Eliminator? The reason I ask is I did so and Langka removes the entire blob, including what was in the paint chip itself. COuld Langka be too strong for the Paint Scratch paint?
Jon
Jon
it sounds as if the scratch is either too shallow, or you are rubbing the surface too hard.
I did the same thing with my kit initially, I realized once I got the touch-up paint melting, to just use light presure to get the surface level.
I found it works better the longer you let the paint dry. I used the blob remover the next day and it removed everything like you said. I redid the touchup paint and waited three days, the paint was tougher to remove and easier to control how much came off. Much better results.
hags1
hags1
Mr. Sparkle
9/11/15 02:57 PM
