Scratch "Removal" Info
Old Mar 13, 2007 | 03:55 PM
davisinla's Avatar
Since there are several "scratch" threads, I thought I'd post this link separately. I'm not sure if you need to be a member of the Meguiars forum to get to this link, but there is quite a bit of excellent info on scratch removal. I've used the techniques successfully several times:
http://www.meguiarsonline.com/forums...&threadid=1516
The bottom line is that if the scratch isn't deeper than the paint level, you should be able to make a vast improvement. But as indicated in the link, you never REMOVE a scratch - you remove material around it so it is less visible.
I'm not a professional, but will be glad to provide any additional info I can.
Old Mar 13, 2007 | 04:02 PM
SteelTownStang's Avatar
Nice link. I've used Scratch X and can attest that it does work
Old Mar 15, 2007 | 01:13 AM
rrobello's Avatar
TMS West Coast Correspondent
scratch x is amazing considering it is used by hand
since this is a helpful thread if anyone knows how to use a DA then Meguiars 80 and 83 (and some others depending on the job) work wonders and get much better results by machine application then you ever will by hand.
Old Mar 15, 2007 | 08:22 AM
davisinla's Avatar
I also use a DA and it certainly makes many operations quicker. It also allows a choice of a wider assortment of products that should not be used by hand. But for a small scratch, I think it's overkill because you want to remove as little material around the scratch as possible.
As I've said, personally, I've had a great deal of success using a microfiber and my finger and a little ScratchX at a time.
YMMV
Jul 8, 2016 08:53 AM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
14Glassback
Sep 11, 2015 04:50 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
