Overspray on a car!!!!! advice needed!!!!!
Old Apr 1, 2007 | 04:24 PM
OKLACOP's Avatar
Hey everyone, I have a vehicle, not my GT, that has overspray or rather splatter all over it. Most of the spots are very small, but some look to be about the size of a dot that a sharpie marker would make. The paint is exterior latex and is water based. Any ideas on how to safely remove it from a vehicle. The vehicle in question is a 01 pewter Chevy 2500 HD. Thanks in advance for your thoughts.
Rob
Old Apr 1, 2007 | 04:45 PM
nonsensez9's Avatar
claybar
Old Apr 1, 2007 | 06:25 PM
jacostang's Avatar
Originally Posted by nonsensez9
claybar
+1
Old Apr 1, 2007 | 06:32 PM
Rob O's Avatar
Go with claybar first & if that doesn't work on it then step up to a cleaner/wax with a light abrasive. If that doesn't work on it then go with a rubbing compound. The claybar should do the trick though.
Old Apr 1, 2007 | 06:52 PM
karman's Avatar
Start with the easy stuff. It's only latex paint.
Throw a wet cloth on it for a while and see how much comes off.
If that doesn't work use "Goof- Off" or "Oops" cleaner.
Why waste claybar on something that should come off easily.
Old Apr 1, 2007 | 11:23 PM
Jim D.'s Avatar
Products like Goof-Off should not be used on most plastics and automotive paints -- always test in an inconspicuous area first.
I prefer Goo-Gone for adhesive and stubborn substance removal as it is milder and more benign.
I'm not familiar with Oops.
You could resort to mineral spirits on cured paint.
If there are many small splatters, the safest bet would likely be clay. If a mild over-the-counter clay doesn't work, try an aggressive clay from a paint or detail supply. Meguiar's has one in their pro line.
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
RRRoamer
Jan 19, 2017 05:27 PM
jc46002003
Apr 15, 2016 03:00 PM
ssjbuu
Aug 28, 2015 08:55 AM
