I made a mustangscicle
9 is not my lucky number.
I took my routine trip to the car wash just now. I use the manual hand wash thing to just spray the road yuckies off. I start spraying the car with the water, I get all the way around the car and noticed none of the water is dripping off. I keep spraying water on and notice the water is freezing and keeps building up. My car was literally encased in ice.
Not real bright spraying water on your car when it's 2 degrees F outside with no windchill. My car looks so stupid now. I had to scrape all my windows before I could drive off with it. It looks like a frozen pipe burst in my garage over my car. It's going to be below freezing for the rest of the week. I have no idea when this stuff will come off.
real dumb
real dumb
Originally posted by bryman@December 13, 2005, 11:37 PM
Extension cord and a hairdryer on hot might do the trick. Better yet, a heat gun.
Originally posted by RFX_Bass@December 14, 2005, 10:10 AM
put it out here in the tropical sun for a while, right now is at 85 F![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
![EEK!](https://themustangsource.com/forums/images/smilies/eek.gif)
Originally posted by WERKED 66@December 14, 2005, 3:18 AM
hot water frezzes before cold water..........
"Jearl (Walker) suggested that the most likely explanation for this was evaporation: when water cools down from near boiling to the freezing point, as much as 16 percent evaporates away, compared to 7 percent for water at 160 degrees. The smaller the amount of water, of course, the faster it freezes.
In addition, the water vapor carries away a certain amount of heat. To test this theory, Jearl covered his lab beaker with Saran Wrap to prevent water vapor from escaping. The freezing rate difference was greatly diminished. Conceivably convection (motion within the water) also plays a role.
Fascinating as all this no doubt is, all it basically proves is that very hot water freezes more slowly than very VERY hot water. The ordinary fumbler in the fridge, on the other hand, is dealing with temps more like the ones I was measuring, in which case cold freezes faster than hot. I rest my case."
More than you wanted to know, I'm sure. But there it is.
Bow Chica Bow Wow
TMS Staff
TMS Staff
look at it this way..at least your car is clean under the ice. it's like driving around with a clear car cover on all the time
