I don't like megs hot rims chrome cleaner
Old Jul 30, 2011 | 05:41 AM
Washed and dried my wheels using the megs chrome cleaner. The next day I noticed some milkey streaks on them. I figured no problem a little megs detail spray will clean that right up...... nope didn't really do the trick. the pick below is after I used the detail spray. So I ended up using some swirl remover on them and it cleaned it up right nice.
I will not be using that stuff again.
Attached Thumbnails I don't like megs hot rims chrome cleaner-megs1.jpg   I don't like megs hot rims chrome cleaner-yuck.jpg   I don't like megs hot rims chrome cleaner-megs-2.jpg
Old Aug 1, 2011 | 03:36 PM
MarcHarris's Avatar
Detailing Guru
Looks like it wasn't rinsed thoroughly. How did you use it? One wheel at a time? Did you use any physical agitation, or just spray and rinse? It might be as simple as using this product in a different method to get the results you're looking for.
Old Aug 2, 2011 | 06:42 AM
rinse, spray product, a little washing, rinse well. I guess not well enough but I thought so. Then I dried them. The streaks came from what ever water ran off the back side of the rim after I was done cleaning the car for the day. I noticed the streaks the next day. The streaks arn't the problem so much as the effort it took to get rid of them.
Old Aug 2, 2011 | 08:34 AM
MarcHarris's Avatar
Detailing Guru
Sounds like you did everything spot on in my book Glenn. If anything, it might be a case of the product working too well: the cleaning elements of the product likely loosened some other things up that later ran onto the wheel lip and re-solidified. Good to know for future cleaning sessions for sure.
It looks like you have non-clear-coated wheels, which makes things little more tricky as they look much better when they're clean (as you know), but require a little more maintenance than most people are willing to give.
Have you considered purchasing and using an electric leaf blower? It makes drying the car much safer (less touching=less chance of swirls), and is especially useful I find when drying things that are a little more tricky (inside the side mirrors, around emblems, tires/wheels, etc). It might be worth a $40ish investment for someone like you that cares for his baby so well.
kennyg
Aug 14, 2023 11:45 AM
OneCoolGT
Off-Topic Chatter
Sep 3, 2015 07:50 AM
Sep 2, 2015 07:33 PM
Jul 20, 2015 06:26 AM
