Engine bay
Old Dec 28, 2015 | 02:43 PM
SGwick's Avatar
Engine bay
Any ideas how safely clean our engine bays? Step? What to use?
Mine is full of dust :-(
Old Dec 29, 2015 | 08:41 AM
godspunk32's Avatar
Every time I wash my 2016, I spray the entire engine bay out with compressed air (I have an 80 gallon compressor), and wipe down the plastic parts with Meguiar's interior dressing. On my S197, things had gotten a little out of hand, so I needed to cover all the electrical bits (and exposed air filter element), then spray everything with a 10:1 mix of Simple Green (10 parts water/1 part Simple Green), let it sit for a few minutes, scrub with a soft brush, then rinse. I did that two or three times, then let everything dry, and dressed it with the interior dressing. I know that various companies make engine dressing, but I've never tried it.
The biggest issue is making sure that if you use water, you're covering your air filter, battery, and alternator with plastic sheeting.
JR
Old Dec 29, 2015 | 08:49 AM
SGwick's Avatar
Originally Posted by godspunk32
Every time I wash my 2016, I spray the entire engine bay out with compressed air (I have an 80 gallon compressor), and wipe down the plastic parts with Meguiar's interior dressing. On my S197, things had gotten a little out of hand, so I needed to cover all the electrical bits (and exposed air filter element), then spray everything with a 10:1 mix of Simple Green (10 parts water/1 part Simple Green), let it sit for a few minutes, scrub with a soft brush, then rinse. I did that two or three times, then let everything dry, and dressed it with the interior dressing. I know that various companies make engine dressing, but I've never tried it. The biggest issue is making sure that if you use water, you're covering your air filter, battery, and alternator with plastic sheeting. JR
thx JR, planning on buying some dressing and soft brush today. So many options online and on YT i wasn't sure
Old Dec 29, 2015 | 09:39 AM
godspunk32's Avatar
Wait...I take back what I said about the Simple Green. I used that on the insides of my rims to clean off the brake dust.
For the engine bay, I used two cans of Gunk Foamy Engine Brite degreaser, according to the instructions on the can.
JR
Old Dec 29, 2015 | 10:10 AM
TripleBlack14's Avatar
Regular maintenance is the key. My Mustang is black so I made a conscience effort to stay on top of it from the very beginning. Water spotting is the worst so the engine bay gets a major detailing after every wash. At least once a week, especially after a lot of driving, all plastic covers get wiped down with Mothers Back to Black and exposed metal surfaces get wiped down with glass cleaner. My coil covers and plenum covers are painted hi gloss black and red. The plenum cover especially is a dust magnet and periodically I take off the strut tower brace so I can remove the plenum for a cleaning and a lite coat of wax.
I admit I'm **** about cleaning, but the results are worth it.
Old Dec 29, 2015 | 10:24 AM
SGwick's Avatar
Wait...I take back what I said about the Simple Green. I used that on the insides of my rims to clean off the brake dust. For the engine bay, I used two cans of Gunk Foamy Engine Brite degreaser, according to the instructions on the can. JR
lol no worries haven't bought it yet :-)
Old Dec 29, 2015 | 10:26 AM
SGwick's Avatar
Regular maintenance is the key. My Mustang is black so I made a conscience effort to stay on top of it from the very beginning. Water spotting is the worst so the engine bay gets a major detailing after every wash. At least once a week, especially after a lot of driving, all plastic covers get wiped down with Mothers Back to Black and exposed metal surfaces get wiped down with glass cleaner. My coil covers and plenum covers are painted hi gloss black and red. The plenum cover especially is a dust magnet and periodically I take off the strut tower brace so I can remove the plenum for a cleaning and a lite coat of wax. I admit I'm **** about cleaning, but the results are worth it.
wow, thx for response I was looking at a black dressing, I'll look in to it. Your engine bay sounds spotless :-)
Old Dec 29, 2015 | 10:53 AM
ford20's Avatar
Do you have pictures of those coil covers?
Old Dec 29, 2015 | 11:36 AM
Happy to oblige....
Old Dec 30, 2015 | 11:17 AM
SGwick's Avatar
Well I just finished cleaning engine bay with gunk cleaner (stage 1) and spray dressing with meguires back to black spray. Not happy with results, recommend others go with gunk original (slightly tougher) and liquid dressing not spray. Don't use terry cloth, it'll leave cotton strands.
Old Dec 30, 2015 | 01:39 PM
2011 Kona Blue's Avatar
If your issue is dust, just by a multi purpose cleaner, spray on and wipe off. Nice and clean
Old Dec 30, 2015 | 03:17 PM
SGwick's Avatar
I think you're right, sometimes the best answer is the simplest :-) thx
Old Dec 30, 2015 | 05:27 PM
If someone finds their engine bay a train wreck from years of cleaning neglect, lack there of, degreaser, power washer and soft brush will clean it right up. Just make sure one covers up an open CAI should one have. Lol.
Top off with a nice plastics shine up spray.
Old Dec 30, 2015 | 10:09 PM
PJRManagement's Avatar
Currently a Corvette Owner!
As someone mentioned earlier in the thread, regular maintenance is the key. I simply use water and rags, nothing else. I make sure to wipe down the underside of the hood, around the felt hood liner. Then of course every exposed piece of body metal. Then the engine cover and coil covers. Then all plastic items. Just water and rages. If done once every 3-6 months since new, no problem. If you have a lot of dust/grease/dirt then you may need the chemicals. Once you do get it clean, try to stay on top of it. The 5.0 engine bay is especially good-looking IMO. I've removed my sound tube, and I think it looks better and is easier to clean that driver's side now.
Old Dec 31, 2015 | 06:05 AM
This is a friend's '09 Challenger....amazingly sanitary and well organized engine bay.
Old Dec 31, 2015 | 08:07 PM
Nice Chally engine bay. Here is a pic of mine (before I removed the sound tube).
Engine IMG 0016
Old Dec 31, 2015 | 08:16 PM
Blue Notch's Avatar
I must be the only person that doesn't despise the sound tube.
Old Jan 1, 2016 | 05:58 PM
Correct, you are.
Old Jan 1, 2016 | 06:38 PM
As some wise member on here said, the key to a clean engine bay is maintaining cleanliness on a routine basis. Just a little 15 minute routine clean will keep an engine bay looking great.
Old Jan 3, 2016 | 07:49 PM
PA-Fatboy's Avatar
I also get the "powerball" out that chip foose sold me and use whatever is my favorite metal brightener at the time on the engine parts to polish. This also works well on the engine bay strut towers and firewall to shine up. I usually do this after it is cleaned and the engine dressing has been applied. I have every version of the "powerball" in my arsenal. *****, cones, big, little... If it can be spun with a drill, I have tried it. I am basically lazy and look for shortcuts wherever possible!
