Clay bar vs. liquid paint cleaner do you really need both?
there's not a certain length, it's basically until you can't find a resonably clean surface when you knead the clay over and into itself
I think I'm going to buy the Meguiars Clay Kit this weekend since it has 2 50 gram bars instead of the 1 80 gram bar in the Mothers kit. Do you all use the entire bar, or do you cut it down into smaller bars? Also, do you flatten the clay completely, or do you make one side have some kind of edge to it to help remove the stuff on the surface?
I've read that it is better to slice it so that it maintains the same largest surface area but in thinner pieces. In the past I have just used the whole bar for a bit and then rolled it around and let it flatten out with use. That is what the usage instructions say but the slicing up seems to make sense.
I usually use one maybe twice and then demote it to wheels. You might also consider using one for upper and one for lower body.
When you are finished for one you want to reuse get a small Ziploc and squirt some quick detailer in to store it.
I always tear off small pieces of clay, use them until they get dirty, throw away, and repeat. I flatten the pieces until they are about 2" or a little less in diameter and fold the section over and flatten again when the first side gets dirty. An entire car usually takes 1/4 to 1/2 of a clay bar (depends if I'm doing the Mini or Mustang).
I'm a little too much of a perfectionist and too detail oriented, a full detail job on a car will take me a couple of days at least to do everything, but I usually try and break it up into sections. I used to take the wheels/tires off and bring them in the house and thoroughly clean them in the bathtub, but my wife put a stop to that a couple of years ago.
Thanks for the tips guys. Cutting them into smaller pieces makes more sense to me since it will help make them last longer. I'm looking forward to trying out the clay bar. I'm probably going to burn through the quick detailer though.
That is awesome!
I don't use my clay bar anymore. Used it one time and it made the worst white spots and streaks on the car. Couldn't get them off. Messed up the wax I tried to use also. I stick to Meguiars Liquid Wax.
keepint the surface wet at all times while rubbing I think is Very important I have bottlke one hane , bar in other ande have a good work out, after I need two sets of sun glass's.
When I cut the first bar in half should I store each piece in its own bag with quick detailer on each piece? Do I need to put quick detailer on the piece if I haven't used it yet?
I would put them in separate bags with quick detailer in both. It just keeps the bag form sticking to the clay. The used one will probably be kind of dirty so keeping them separate would be optimal.
Super Moderator
TMS Staff
TMS Staff
The clay bar it self will "load up" with debris, then throw it away. Have seen folks continue to use clay bars way past their time and start scratching and marking their paint with them.
Remeber, keep it wet, and fold it over.
TDS
TDS
Thanks, TDS. I imagine I'll be able to feel or at least see a difference in the clay bar after I use it a couple of times. I should be able to clay my car 2-3 times with one bar right? So if I cut each bar in two, I'll have to really watch how dirty the smaller pieces get.
WOW! I finally went and got the Meguiars clay kit. I cut one bar in half and used one half on most of my wife's car (gotta practice before using it on the Mustang
). It really is amazing how much crap it pulls off of the car and how much easier the liquid paint cleaner goes on and off. One last question, should I re-nead the clay after every section or just when I notice the surface starting to show contaminents?
Thanks again for all of the help.
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
it really is amazing stuff...used mine today actually
just knead it when it starts getting dirty, sometimes that's a few panels, sometimes its only half of one.
Ok, that makes sense. I noticed that the hood was nasty as hell, but there were other panels that you couldn't really see anything on the clay itself.
I'm not going to use it everytime, but I am definately hooked.
