Best oil to use for 2011 3.7?
Motor oils that you can't go wrong and top quality: Mobil 1 Extended Performance, Amsoil, Redline and Royal Purple. I personally use Mobil 1 extended performance but the others are great as well.
I have used both Mobil One & Mobil One Extended. Both oils were black after 5,000 miles. No difference so now I use the regular Mobil One and change it every 4-5,000 miles. Motorcraft filters from Wallmarts or sometimes the dealer.
The oil is supposed to be black. That's not bad. The Extended Performance has different additives to make the oil last for up to 15,000 miles of for an oil change interval
As far as the warranty is concerned anything that meets the factory requirements.
I run 5-30 full synthetic as I run my car or pretty hard and feel better running that versus the 5-20. For normal usage the 20 weight stuff is fine and Motorcraft 5-20 is very cheap.
All the oil test i have read, they used 5w30. Why? I don't know why. I also read, 5w30 thinned down to 5w20 on a hot summer day. Started me thinking, what would 5w20 thin down to on a hot summer day. I never could find an answer to that because 'all' the oil test i could find used 5w30 weight oil. Best i can find, 5w30 is the standard weight oil in Europe and 5w20 is very hard to come by.
These are most of the reasons why i use 5w30 weight oil
Not trying to start an 'oil war'. 5w20 is okay to use.
m05fastbackGT
Dec 20, 2015 03:10 PM
