18" Polished Aluminum Bullits...Clear Coated?
Title says it all. Are the polished aluminum Bullits on my 2006 GT clear coated or not? I have a spot on one of the wheels that I can not get off with a detailing clay bar. I’ll try some metal polish next but only if the wheels are not clear coated.
Mike
Mike
Originally Posted by habu
I have the same wheels and have never had wheels that were clear coated. is there special handling that I should worry about ??
Claybar will not harm them either as it don't hurt the paint on the car.
Oh man am I glad I read this thread. My '07 has 17" Bullits that I now assume must be painted and clearcoated . I guess waxing is a better idea for the spokes and polish for the aluminum rim. Used a Mother's wheel polish all over them this w/e but I won't do that again.
I would never have thought of waxing wheels in a millions years. It makes sense though... what sucks is I just finished claybaring mine and put a couple coats of Zaino on it... cleaned the wheels and that's it. Gonna have to bust out the clay bar and wax here in the next day or so...
Thanks for the info. You learn something new everyday here
OK, that makes sense. So if you're OK to clay bar 'em, do you wax them too ?? It just seems like a real dumb question.
I appreciate your help
Originally Posted by VVVROOM
My 18" polished wheels each have a spot where it looks like there was a factory sticker on them. Any ideas how to get this off without damaging the finish?
Yeah waxing wheels like this is a good idea. When I got my polished Weld Draglights way back when I waxed them about once a month, they were insanely easy to keep clean because of it.
I think it works better than wax on the wheels.
I'm a Zaino guy too and have always used it on clear coated wheels. I assumed the polished Bullits were clear coated but asked just to be sure.
As for the spot on the wheel that started all this....it appears to be under the clear coat. Something must have gotten on the wheel at the factory prior to putting on the clear. I've only had the car for 2 months so I'll have to decide if it's worth taking this up with the dealer.
On a side note....the clear coat on the wheels seems to be much softer than what's used on the body. My detailing process has never caused scratching on any of my cars but I noticed some very light marring on the wheels...none on the body.
Sticker on each wheel
Does anyone know if there is a reason to have the tires aligned with the wheels using the red dot on the tire and the sticker on the wheel?
Should the red dots and stickers be left on so that in the future when the tire is remounted on the wheel, the red dot gets aligned with the sticker?
Thanks.
I have one sticker on each of my wheels. I am wondering if the sticker has something to do with aligning the tire with the wheel. There is a red dot on each of my tires that lines up next to the sticker on each wheel.
Does anyone know if there is a reason to have the tires aligned with the wheels?
Thanks.
Here are links to bigger pictures of one my wheels.
http://i36.photobucket.com/albums/e4...n/100_0007.jpg
http://i36.photobucket.com/albums/e4...n/100_0005.jpg
http://i36.photobucket.com/albums/e4...n/100_0006.jpg
Thanks.
Paul
Sticker and red dot used to align wheel and tire?
Thanks.
Thanks.
Also, why would they be putting these stickers on the rims and red dots on the tires in the first place? What, is this just part of an "Annoyance Program" to give us something to ponder and work on in our spare time?
Maybe you can see the sticker on the rim and red dot on the tire lined up next to each other better in this picture.
Thanks.
Here's what I used to remove the little sticky squares off the rim (Goo Gone didn't do it for me ). And I used my fingernail (with a little Z-10 ) to scrape the red marks off the tire.
before
after
