What does "modular" mean?
Old Apr 6, 2005 | 08:22 AM
hi_stik's Avatar
Thumbs up
Does the term "modular" mean that this motor can be modified by swapping parts? For example, can the single overhead cams be removed & replaced w/ a dual overhead cam intake? Or something of a similar nature?
Just wondering...
Old Apr 6, 2005 | 08:44 AM
pushrod power's Avatar
modular in this case mean that many versions of this motor can be made from a V6 to a V10 because they all share the same bore spacing and basic block archetechture(spelling?). you can't switch from 1 cam to 2 without switching the head as the cam housings are cast into the heads. but if you want to switch from an SOHC head to a DOHC head and intake, the parts will bolt on, but there is more to it than that.
Old Apr 6, 2005 | 12:21 PM
hi_stik's Avatar
wouldn't be fairly simple, like reprogramming, or "re-chipping" the computer to take into account the DOHC configuration? It's all academic, because I'm poor, but I'd like to investigate the issue.
Old Apr 6, 2005 | 12:57 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Well I believe there may be a slight bolt pattern difference between early model DOHC's and 99+ SOHC motors. You should be able to put 99/01 heads/intake on a 99+ SOHC car. Yes you would have to chip it to make it run correctly.
