Warranty exception?
Warranty exception?
So i take my stang to an official dealer in for an oil change, bring it back, and see all my stuff adjusted. So i try to use the up / down seat adjustments only to find out its not working... I never touch that, neither anyone else drives my car.... So now what? I am pretty pissed tho, how can i tell ford that its not working as before i brought it in? its not even 3 years old, but has 37k. Do you think i will have problems? The dash also has squeals... I want them to cover all that...
How about taking the car back and ask the service department to take a look? I picked up my car one time and something wasn't working and the fix was as simple as a connector was not fully plugged in. I understand you are unhappy that the seat stopped working, but first give the dealer a chance to make it right. You might be surprised.
Like Father...
I ♥ Sausage
I ♥ Sausage
Seems to be a common problem, and you're probably SOL.
https://themustangsource.com/forums/...overed-539656/
They'll be glad to fix it for about $900 apparently.
Anyhow, I bought the car on the 7th of December for an Oil change. Everything worked other than the rattle/squeak that came from the dash area ( something that they wanted to take a look )
I been taking my car to the dealer every time. What sucks is that I bought the car, and adjusted the seat only once. Never touched it again, the fact that it failed this early is BS! The only time i have to re-adjust my seat is each time after service since my tech has to adjust to fit in ( not to blame anyone )... Something has to be done!
12/17/15 12:11 PM
