one wheel burnout blues
Old Mar 7, 2005 | 10:17 PM
Final5pt0's Avatar
i own a 95 GT with bout 123,000 miles on it. still running strong. ive added a set of frod racing 1 5/8 headers, bassani x pipe, and flowmaster catback system to the car. the next area i want to adress is my rear end. i want to upgrade to 3.73 gears, and to fix the nagging problems of doing one-wheel burnouts and leaving one tire mark (hey everyone leaves rubber sometime ) after a take-off. i know that a traction lock differential/posi rear is the answer, but i dont know much about gearing , so anyone who has a suggestion on a set up or some good (and budget minded) brands to go with. when i mentioned changing gears to my mechanic he said i would most likely have to change my axels too, is this true?
well anyone with experiance/knowledge of this please share, thanx
ps the car is a 5speed
Old Mar 8, 2005 | 12:09 AM
Dark02Pony's Avatar
im not so much an expert when it comes to rear gears myself so im not sure if changing the axels but i dont think you have to..when it comes to installation on rear gears ( 3.73 is prob what id do for the 5spd ) is what gets you, over here its around 200 or so for installation then of course more for trac-lock
Old Mar 8, 2005 | 01:29 PM
Hotrod's Avatar
You shouldnt have to change the axles if the gear is a similar size as the old one. By that I mean the package size. I dont really know of any brands for gears but rear some articles in MM&FF to see hwat others have used. You might also want to check out hotrod mag (or if worse come to worse you could check Super Chevy).
Old Mar 8, 2005 | 02:03 PM
lilbossman's Avatar
hotrod is right you dont have to change the axle if it is around the gears you want to go for.
Old Mar 8, 2005 | 03:16 PM
Final5pt0's Avatar
thanks guys keep the advice coming
Old Mar 8, 2005 | 06:39 PM
future9er24's Avatar
i think they did 3.73s in Horsepower TV once. everything was fine. go for it dude
Old Mar 8, 2005 | 07:32 PM
Final5pt0's Avatar
thanx
Old Mar 8, 2005 | 10:34 PM
Ballz's Avatar
3.73 are the popular choice for the 6. I've never heard of having to change the axle.
Old Mar 9, 2005 | 04:55 PM
Fordracing200's Avatar
to get a 2 wheel burnout you need a posi, gears wont make a difference as in the amount of wheels turning, and you need to pull your carrier pin and remove the c clips to chnage the rear gears.
Old Mar 9, 2005 | 08:33 PM
Final5pt0's Avatar
Originally posted by Fordracing200@March 9, 2005, 7:58 PM
to get a 2 wheel burnout you need a posi, gears wont make a difference as in the amount of wheels turning, and you need to pull your carrier pin and remove the c clips.
a tractiuon lock differential wont do?
if i remove the carrier pin ant the c clips i can do this with the stock rear end?
Old Mar 10, 2005 | 06:40 PM
u remove the carrier pinn and c clips to change rear gears, and u buy a limited slip or traction lock or posi rearend for 2 wheel burnouts, ok?
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
Jul 8, 2016 08:53 AM
M3hunter
Sep 10, 2015 09:26 AM
earl610
Sep 6, 2015 05:48 PM
JonathonK
Sep 4, 2015 02:41 PM
