Need help!!! 06
Old Jan 26, 2012 | 08:42 PM
quikazzstang's Avatar
Need help!!! 06
I have a squeaking sound coming from motor and I've replaced ideal pulley and tension and it still squeaks .... Any ideas what it could be
Old Jan 28, 2012 | 09:49 AM
wheelman's Avatar
Had a similar problem, replaced the tensioner, which helped a little, but later found that a shop had used silicone on the belt, thinking that would help, which is just dumb in most modern vehicles. Had to replace the belt and clean the pulleys. If its squeaking, its some problem along the serpentine.
Old Jan 28, 2012 | 10:11 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
I spray the belt with a little wd40. See if that stops it. If it does replace the belt.
