I am new here
My Mustang and other cars' specs and some pics:
Below is my butt-kick'n 1987 LX 5.0 Ford Mustang. This car has been a labor of love for many years and is mainly a car show participant/street cruiser; it is always evolving into something more radical. Right now I guess you could say that it is a "street" Street Renegade car with road race flavor (strange mix huh?). This car has many modifications and I am only listing some here. I'll just say that I have over $50,000 invested in my baby and I keep pouring more labor and money into it! Just one thing though, my father and I did ALL the work on this car ourselves, and we have enough of a machine shop in our garage that there is a lot of one-off custom fabricated parts on this car. If you would like to know more, just e-mail me at: mattsstang87@yahoo.com.
Engine and Drivetrain:
Block: FRPP Sportsman with a Canton girdle and windage tray
Bore: 4.00 inch
Stroke: 3.40 inch
Displacement: 342 cid
Crank: Probe lightweight forged steel, ATI damper
Rods: Probe ultra-lightweight, 5.315 inch
Pistons: Probe SRS, 12.5:1 compression, Sealed Power low-tension rings
Oil Pan: Canton 7 Qt baffled with crank scraper
Cooling: Ron Davis aluminum radiator, SN95 electric fan, Stewart water pump
Cam: BIG Comp Cams solid roller with Comp Cams lifters
Heads: Edelbrock Victor Jr.(WELLSpeed ported); K-Motion valve springs, Comp Titanium retainers, Harland Sharp 1.6 roller rockers, Comp High-Tech pushrods
Valves: 2.05/1.60
Intake: Edelbrock Victor 5.0 EFI (WELLSpeed ported)
Throttle Body: Accufab Race 85 mm
Mass Air Meter: Pro-M 80 mm with a custom WELLSpeed 4 inch intake pipe and Powerstack filter
Power Adder: Custom 50-300 hp nitrous system (600 hp on dual stage setup) utilizing an NX Gemini-Twin Plate and NX Iceman solenoids, grill mounted purge
Fuel System: Mallory 110 FI pump, twin Mallory filters, Magnafuel regulator, Vortech fuel rails, FRPP 42 lb injectors, Ground Pounder pick-up, -10 /-8 supply and -6 return lines
Headers: Bassani 1-3/4 to 1-7/8 inch long-tube headers
Exhaust: 3 inch Bassani off-road x-pipe, 3 inch Race Magnum bullet mufflers, no tail pipes
Transmission: FRPP Z T-5, SPEC aluminum flywheel, SPEC Stage IV High-RPM clutch and pressure plate with lightening option, FRPP aluminum driveshaft, Pro-5.0 shifter, urethane mount
Rear-end: 8.8 with Auburn Pro differential, Moser axles, 4.30 gears
Electronics:
Engine Management: A9L computer, custom Autologic 4-position chip from JMS, FRPP Extender, PLX wideband w/Autometer gauge conversion
Ignition: Mallory HyFire VI Multiple Spark Discharge CD box, MSD Pro Billet distributor, Mallory coil, FRPP wires, NGK Iridium plugs
Gauges: Autometer Phantom Speedometer, Tachometer, Shift-Lite, fuel level, volts, oil pressure, water temperature, fuel pressure. Edelbrock nitrous pressure
Other Controls: Custom switch panel for nitrous plus stuff and things
Suspension and Chassis:
Front Suspension:
K-Member: AJE Tubular, custom solid motor mounts for 1 inch lower engine
Control Arms: Ground Pounder tubular
Springs: Ground Pounder coil-over kit; QA-1 progessive (175-350) springs
Sway Bar: Suspension Techniques
Steering: Flaming River 15:1 manual rack and custom shaft, Ground Pounder bumpsteer kit, Maximum Motorsports solid mounts
Struts: Monroe Formula GP with Ground Pounder caster/camber plates
Brakes: Power Stop cross drilled rotors, Lincoln 73 mm calipers, Hawk pads
Wheels and Tires: Centerline Billet 17x8 inch with Yokohama A520 245/45/ZR-17
Rear Suspension:
Control Arms: HP Motorsport Mega-bite Jr. lowers, modified stock uppers with urethane bushings
Springs: FRPP M-5300-C
Panhard Bar: Modified BBK
Shocks: Monroe Formula GP; no quad shocks
Brakes: SSBC slotted rear rotors, Porterfield pads
Wheels and Tires: Centerline Billet 17x8 inch with Yokohama A520 255/45/ZR-17
Chassis Stiffening: Steeda chrome-moly subframe connectors and custom chrome-moly G-load brace
Exterior:
Color: 1987 Specific Ford Medium Yellow (Code 6H)
Hood: Cervini's 3 inch cowl-induction
Rear Spoiler: Cervini's Mustang Anniversary Wing
Lights: Clear fronts, Black 1987-1993 GT rears
Other: Running Pony emblems, Saleen front filler panel, sunroof, and few nicks and dings from driving (yes, it is driven whenever I have the chance!
Interior:
Seats and upholstery: Flo-fit front buckets with lumbar support, rear seat (and door panels) covered in matching Flo-fit material
Shifter: Pro-5.0. with a Hurst stick and button T-handle
Instrumentation and other controls: Autometer Phantom, custom panel with aircraft switches
Steering wheel: Grant billet with leather wrap
Bling: Billet window switches and panels, billet HVAC control *****, billet door handle bezels, billet steering tilt handle, billet coat hangers, billet door lock *****, billet parking brake handle, chrome fire extinguisher
http://i11.photobucket.com/albums/a...87/000_0053.jpg
http://i11.photobucket.com/albums/a...87/000_0137.jpg
http://i11.photobucket.com/albums/a...87/000_0055.jpg
http://i11.photobucket.com/albums/a...87/000_0051.jpg
In progress...
http://i11.photobucket.com/albums/a...87/000_0622.jpg
http://i11.photobucket.com/albums/a...87/000_0623.jpg
http://i11.photobucket.com/albums/a...87/000_0624.jpg
**Look for the car in 5.0 Mustangs and Super Fords magazine (August 2005 issue) and Mustang Enthusiast magazine (June 2005 issue). It won Editors Choice at the NMRA Ford All-Star Nationals (Columbus 2003), and at the NMRA World Finals at Bowling Green (2004) two feature shoots were done on it!!!!**
Below is my silver 2000 Ford Lightining. This baby is really bad, and made a great toy. I estimate that it now has at least 425-450 rwhp (around 525-550 hp flywheel [23% driveline loss]) with bolt-on parts. It now has a custom exhaust, bigger MAF, a custom PSP chip, and more boost to name a few of the mods.
http://i11.photobucket.com/albums/a...htning_1_42.jpg
Here are the mods to my 2003.5 Mazda Protege 5. The mods: Custom/Vibrant exhaust, OBX header, WELLSpeed midpipe, WELLSpeed CAI, R-R Racing UDP, MP3 ECU, KartBoy shifter bushings, shortened shifter with a billet Mustang ****, Redline fluid, stainless clutch line, Progress springs, Progress 22mm rear swaybar, Polished PR5 wheels with Kumho Ecsta 712 205/50/ZR16, and Dave B rings, J-Spec intake camshaft, removed VTCS and ported intake, Tokico HP Struts.
http://i11.photobucket.com/albums/a...87/000_0520.jpg
Bore: 4.00 inch
Stroke: 3.40 inch
Valves: 2.05/1.60
Electronics:
Front Suspension:
Rear Suspension:
Exterior:
Interior:
In progress...
