how can I get a 9 sec mustang
Old Aug 13, 2016 | 07:53 AM
93lxmustangshawn's Avatar
I have a 93 mustang and I took it out to the track yesterday and wasn't really happy with results specially because of the money that was spent into the car....the car does have all original doors on it, and still have original block as well but the internals are brand new....brand new pistons,brand new crank,brand new heads,brand new tires, brand new bearings, brand new push rods and brand new rocker arms, 12:1 compression, 6.40 lift cam, not exactly sure what's the intake and what's the exhaust lobe for cam, AFR renegade heads car is stripped for weight reduction, had issues with the thottle cable and trans mission but still the car didn't run a good time what can be possibly some of the issues ?
Old Aug 13, 2016 | 09:00 AM
what are you running as far as fuel supply? Have you had it on the dyno yet? That will tell the story
Old Aug 13, 2016 | 09:03 AM
Joeywhat's Avatar
Stop the clock at 9 seconds?
A dyno-results and tune will really be helpful. Right now it's like trying to diagnose a major medical issue over the phone.
Old Aug 13, 2016 | 10:02 AM
HOSS429's Avatar
legacy Tms Member
run the 1/8 mile tracks ...
Old Aug 13, 2016 | 10:14 AM
No never been dyno'd all motor we run 112 and on nitrous(which we haven't ran the car on nitrous yet) will run c16
Old Aug 13, 2016 | 10:15 AM
I'm going to try that I'll have to find a good carb tuner,
That's kinda really what the car was set up for the 8th if a mile track but the time turn yesterday wasn't impressive at all
Old Aug 13, 2016 | 10:27 AM
HOSS429's Avatar
legacy Tms Member
practice will help a lot .. the first time i took my Tbird years ago it did not do well .. with nothing more than a little experience and some fine tuning i dropped a full second in the 1/8th .. being set up for the 1/8th may have you a bit too low in gears ..
Old Aug 13, 2016 | 10:52 AM
Yeah I was talking to some other mustang guys and they was telling me try 4:10 gears that might be a little better we took out 3:55 gears so I'm going to try a different combo
Old Aug 13, 2016 | 06:25 PM
AlsCobra's Avatar
A Man Just Needs Some....
9 seconds is tough in a fox body. Really tough. Car is just not right for 9's. Gonna need a good 4link set up. Big sticky tires. Low gears. Big stall converter. And probably at least 600hp. Sounds like you're a long way from 9's. Even then, that will be a hard car to control. 9's are easy in the newer 5.0's but you are heading towards a lot of heartache trying to get that fox where you want it. I would cut your losses and build a different car if 9's are your goal.
Old Aug 13, 2016 | 06:44 PM
Not sure if you read my description but I got almost all the key ingredients to have a 9 sec fox body mustang just I know it's something that I'm missing that not moving my car to the 9 sec mark, not sure if it's the transmission or if the car need to be tuned where I'm from its plenty and I mean plenty of guys that run N/A fox bodies that make it to the 9s with nitrous I'm not sure what they internals are but they are not that different from mines
Old Aug 13, 2016 | 07:03 PM
AlsCobra's Avatar
wasn't sure if you were running nitrous or not. Big gears and stall. Good tune. Suspension is a must. Without a good suspension set up, it will be tough. What tires are you running? What are your 60ft times? How does she handle on the top end? Get it on the dyno and get some real time numbers. See when you are making peak hp and when she is weakest. It may come down to timing or camshafts. I didn't mean to downplay your car because I love the hell out of the foxes but if I was to build a racecar, it wouldn't be a fox. I would love another fox but not for anything more than some street racing.
Old Aug 13, 2016 | 07:13 PM
Oh no I didn't take it as if you were down playing my car I came here for opinions and help and your helping me out with your opinion it's a 347 c.i stock block though, AFR heads, Hoosier tires 29inch 10.5 tires, can't remember the suspension but it's aftermarket, k-member in the front, hooker headers, 750 carb, coated pistons, titanium push rods, 3800 stall c4 tranny reverse manual valve body, 12:1 compression, and 6.40 lift on the cam but it's plenty of bugs that need to be worked out took it to the track yesterday and she was running lean after 1 pass down the track in a 8th but the issue is the tranny started messing up and the throttle cable broke, also 8.8 in read with 4.56 gears
Old Aug 13, 2016 | 07:19 PM
There isn't any way the stock 302 block, I realize all internals are good, but you're gonna need a Dart block to get the horsepower to do 9 seconds. There is no way the stock block holds for any serious amount of time.
Old Aug 13, 2016 | 07:22 PM
Thanks I been hearing that the stock block 302 isn't good for that power so basically a dart block or what else I was told was a 351w block
Old Aug 13, 2016 | 07:33 PM
If you have to start over go 351 dart block and don't look back
Then like al said your only problem will be there rear 4 link setup
Some even question the stock 351w f4te roller blocks. Some say to use them others say you gotta get the early 70s ones which are hard to find.
Old Aug 14, 2016 | 07:07 AM
Yeah the hard to find ones would be the Cleveland blocks which are extra hard to find
Old Aug 14, 2016 | 10:36 AM
kcoTiger's Avatar
dohc97
Mar 9, 2016 07:00 PM
Blown CS
Mar 4, 2016 10:34 AM
killaz05
Feb 18, 2016 02:46 PM
TMSBrad
May 3, 2004 10:48 PM
