Help with HID headlights?
Old Jul 30, 2012 | 05:57 PM
SilverSkoundrel's Avatar
We are trying to install HIDs in my cousins 97 GT. the original wire colors are red/black, green/black, and solid black. Blacks in middle. New wire harness come not hooked up to the plug with 3 different colors blue, brown, and white. Help please!!!
Old Jul 30, 2012 | 05:59 PM
Here's pics
Attached Thumbnails Help with HID headlights?-image-3268064878.jpg   Help with HID headlights?-image-3669082096.jpg
Old Jul 30, 2012 | 06:07 PM
I have got to get this going within the next couple hours!!
Old Jul 30, 2012 | 06:17 PM
Anyone guys?
Old Jul 30, 2012 | 06:26 PM
srry I can't help no instructions came with the lights?? call the place you got them from tomorrow
Old Jul 30, 2012 | 06:41 PM
It's online :\ I emailed but doubt they will answer till tomorrow. I know the bulbs are good. We tried them on my car. We can't get anything out of his
Old Jul 30, 2012 | 06:46 PM
PJRManagement's Avatar
Currently a Corvette Owner!
When installing aftermarket HID conversion kits, it is necessary to specify if your current set-up uses one headlight for both low & high beams, or two headlights. One headlight (like my 2011 GT) will require a BI-XENON conversion kit. What I think might have happened to you is you ordered the wrong kit...otherwise the connections should snap together...maybe?
Old Jul 30, 2012 | 06:50 PM
It is a bi xenon specific hi and lo kit 9007
Old Jul 30, 2012 | 11:07 PM
Well, then, I think you got a kit that does not match properly. Most (quality) HID conversion kits do not require you to splice wires. The harness matches up, and snap in to your OEM connections. Check out www.xenonsupply.com , that's where I got mine, no problems with install.
Old Jul 31, 2012 | 05:47 AM
It's not splice in though. In the picture with the wires we where trying to figure out what colors went in which order to the plug on the left. Then that plugs into the first picture
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
50Cal
Sep 17, 2015 06:43 PM
