Goodness...
Old Apr 27, 2011 | 08:41 PM
Weeman333's Avatar
Goodness...
Howdy All. I got an ext. Stuck on my piston arm . I dropped it through the distributor hole and thought it went to the pan... Well it didn't lol. Turned it over and bam. Right in there, an I can't turn the motor either way.
Old Apr 28, 2011 | 05:59 AM
DUDE!
Old Apr 28, 2011 | 08:24 AM
Onelildude's Avatar
have you tried to get it out with a magnate?
Old Apr 28, 2011 | 12:15 PM
stupidgenius36's Avatar
Just Plain Rude!
That's what I was gonna suggest...Or you could try a magnet.
Old Apr 28, 2011 | 12:33 PM
11SHELBYGT500's Avatar
It looks like it's jammed in there. Have you tried to us some long nose pliers?
Old Apr 28, 2011 | 02:02 PM
You do have all the plugs out so there's no compression right? Seems like you could back the crank the opposite way you turned it just a bit to at least make sure its not jammed. Then the needle nose pliers.
Old Apr 28, 2011 | 02:30 PM
godspunk32's Avatar
This. Use a breaker bar on the crank bolt to turn the engine backwards.
JR
Old Apr 28, 2011 | 06:55 PM
houtex's Avatar
Good grief. Ow. Poor car. Hope it comes out ok.
Old Apr 28, 2011 | 08:41 PM
I going to say that you should add some restore and some marvel mystery oil to the radiator. Then charge the battery up really well and try turning it over again
Old Apr 28, 2011 | 09:39 PM
Weeman333's Avatar
I think I might try to cut it in half . I can reach in there and grab it, but I can't crank the motor enough to turn it over
Old Apr 29, 2011 | 05:45 AM
push start it??
Old Apr 29, 2011 | 11:19 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Originally Posted by Glenn
DUDE!
I'm with this guy.
Old Apr 30, 2011 | 11:40 PM
Weeman333's Avatar
Got it!
Old Apr 30, 2011 | 11:41 PM
Weeman333's Avatar
Thank you all for the help .. We broke it with a drill lol
Old May 1, 2011 | 09:16 AM
houtex's Avatar
Gratz on your achievement unlocking!
Now... is everything ok with the engine?
Old May 1, 2011 | 09:53 AM
I don't believe..<---that is all
Old May 2, 2011 | 01:32 AM
Weeman333's Avatar
One piece at a time. And a big thank you to Glenn. Thanks fr being he biggest tampon on thus forum your the coolest
Old May 2, 2011 | 09:49 AM
lol!
