Ford Racing’s New 4.6 Stroker Short Block and New Z2 Head
http://www.stangtv.com/features/pri-...d-new-z2-head/
At this year’s Performance Racing Industry show, Ford Racing was showing off something that many 4.6 fans will be very interested in. An all new 5.3 crate short block, that is based on the 4.6 architecture, and is compatible with two, three (SOHC), and four-valve (DOHC) 4.6 liter heads.
The engine features a solid and proven foundation, and according to Ford Racing’s Mike Delahanty, is ready for just about anything. “If you want the biggest possible modular 4.6 based engine you can build, whether you want to go NA, power adder, or go crazy, this is it. The idea is you can use this as the foundation to build an engine for anything from a mild cruiser, up to something that can go racing.”
Features of the short block include:
-Built from all new parts, not remanufactured
-Based on BOSS 5.0 modular block (4.6 architecture)
-94mm bore
-5.3 liter displacement
-Eagle forged h-beam rods
-Eagle forged stroker crank
-MAHLE forged pistons with three-valve cylinder head compatible valve relief
-Compatible with two, three, or four valve 4.6 heads, including Trick Flow
-Compression ranges from 9:1 to over 10:1 depending upon cylinder heads
-94mm bore
Interesting, what is with the additional block to head alignment dowels pictured. When I built my 4.6L Aluminator there were only alignment dowels on the bolt holes at each end?
