DOT 4 Brake Fluid price is higher than DOT 3
Old Mar 23, 2026 | 08:30 AM
NC14GT's Avatar
I just did the brake fluid on my 3 cars and noticed that the DOT 4 by Ford Motorcraft is almost double the DOT 3 for my Mopar and GM. Since I am no mechanic by any means I was wondering why the DOT 4 is more pricey.
Old Mar 23, 2026 | 09:17 AM
05stangkc's Avatar
Short version DOT 4 is More Expensive To Produce! It Has a Higher Boiling Point and Additional Ingredients in it!
KC
https://blog.amsoil.com/dot-3-and-do...SAAEgKvxvD_BwE
DOT 4 brake fluid is more expensive than DOT 3 primarily
due to its superior performance characteristics, specifically higher boiling points (both dry and wet) and the inclusion of borate esters. These additives enable better performance under extreme heat, such as in high-performance, heavy, or ABS-equipped vehicles, resulting in a more complex, costly formulation.
Key Reasons for Higher Cost:
Higher Performance: DOT 4 is designed to resist boiling at higher temperatures
Advanced Formulation: It includes borate esters that help manage higher temperatures and reduce moisture absorption effects, creating a more robust, expensive product to manufacture.
Added Value/Benefits: DOT 4 is safer for heavy-duty, high-performance, or modern ABS braking systems, which justifies a premium price for better safety and braking performance.
Old Mar 24, 2026 | 02:36 PM
NC14GT's Avatar
^^^ Thanks!! I probably knew that at one time but forgot. Maybe I don't need to do it so often then. I'm just in the habit. It still gets 'dirty' looking in the reservoir. .
Old Mar 25, 2026 | 07:52 AM
Bert's Avatar
I have used Castrol? synthetic DOT3/4 and it works fine as far as I can tell; price is very reasonable at the local auto parts store or maybe even Walmart
Old Mar 25, 2026 | 08:26 AM
NC14GT's Avatar
^^^ That's probably the smart thing to buy. I get 'antsy' buying certain products though, and instead of worrying about it, just buy the products with the Ford, Mopar, GM names on them. I still even buy Motorcraft oil and filters for the GT.
Old Apr 1, 2026 | 05:26 AM
rocknrod's Avatar
Clean Machine Supercharged S-197 Member
I just replaced the brake reservoir on my 05. Also power bleed the brake system of the old fluid using synthetic brake fluid.
brasil
Aug 24, 2019 08:37 AM
BrianB
Mar 17, 2011 03:24 PM
Chaotic Bliss
May 19, 2007 02:12 PM
PonyLover
Sep 14, 2006 07:53 PM
Big D
Sep 19, 2005 09:02 PM
