Bullitt Shifting
Old Jul 18, 2007 | 01:13 PM
Bullitt Shifting
This may sound like a noob question, but in the movie Bullitt, is McQueen pressing the clutch to go into neutral, then again to go into gear, with rev in btwn, or is he pressing it once to go from gear to gear, and revving the engine before letting off. And also, what is granny shifting? I'm a little confused.
Old Jul 18, 2007 | 01:31 PM
Cheese302's Avatar
he is whats called "double clutching" this is a technique used to reduce grinding of gearboxes that have helical cut gears and no synchros. Its very weird however due to the standard 4 speed in that car had synchros in 2-4 gears, leaving only reverse and first to not be synchroed. However in almost all modern road going manual gearboxes. Doubhle clutching is not needed.
Old Jul 18, 2007 | 01:42 PM
AFBLUE's Avatar
Dethroned Nascar Guru
I had heard the sounds were actually from a Ford GT (the LeMans race car)
Old Jul 18, 2007 | 01:51 PM
I meant, what exactly is he doing with the pedals, and while I'm at it, how do you heel and toe, I read about it a while ago, and it may be a repost, but I forgot.
Old Jul 20, 2007 | 08:41 AM
boduke0220's Avatar
isnt granny shifting just the opposite of speed shifting? your just shifting to get where your going, nothing more
Old Jul 21, 2007 | 07:05 PM
Every_Mn's Avatar
Appareantly it was taped over from a small block-powered Ford GT40 racecar, yeah. No idea why he's double-clutching.
EDIT: I should clarify that apparently only SOME parts were taped over. When he starts it up and is kinda cruising at the beginning of the chase it's the real deal.
Old Jul 21, 2007 | 11:51 PM
Id always wondered if that was a real GT 390. I always thought that some of the sounds were quite a bit throatier (word?) than any 67 390 Ive ever heard.
Old Jul 23, 2007 | 11:11 AM
Cheese302's Avatar
think clutch to take the car out of gear, release the clutch, blip the throttle, push the clutch back in and shift into the next gear. and do it in about 1/10 the time it took you to read this
Old Jul 25, 2007 | 10:50 AM
great description, lol
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
Gabe
Sep 7, 2015 03:30 PM
